跳转到主内容
Blackberry KeyONE  Speaker Replacement
raven
raven2 其他贡献者
最后更新于 June 24, 2019
10分钟
中等
社区贡献指南
你所需要的
工具
查看更多...
  1. Blackberry KeyONE  Speaker Replacement, Remove top cover: 步骤 1 中的图像 1,1
    • Carefully remove the top plastic cover. It is hold in place by adhesive.
  2. Blackberry KeyONE  Speaker Replacement, Remove upper frame: 步骤 2 中的图像 1,2 Blackberry KeyONE  Speaker Replacement, Remove upper frame: 步骤 2 中的图像 2,2
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
  3. Blackberry KeyONE  Speaker Replacement, Replace speaker: 步骤 3 中的图像 1,1
    • Now the speaker just slides out.
结论
3等其他人完成本指南。
raven
于09/02/15注册
1,080 声望
创作了4篇指南
3指南评论
Trickiest part was removing the top piece. I used a razor blade to lift the edge, then a guitar pick to finish pulling it up. Thanks for the instructions.
Brian Wiebe - 回复
Be careful with the razor blade or it will slice the top of the flex which you can see folded over the top of the frame. This is not what you will really want to do as you will now be replacing the flex too.
eric Aspinall - 回复
thanks for the guide! was unsure how the phone came apart besides the back cover. took a few tries to get a hang of luckily i had started on the ones with totalled enclosures.
echow2001 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 5,138
