跳转到主内容
加入维修社区 - 创建账户
Beats Studio3 Wireless Hinge Replacement
你所需要的
    1. Beats Studio3 Wireless Hinge Replacement, Ear Pad: 步骤 1 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement, Ear Pad: 步骤 1 中的图像 2,2
      • Find the separation between the headset and ear cushion.
      • Use an opening tool to go underneath the separation site and split the pieces apart.
      询问修复机器人
      添加评论
    2. Beats Studio3 Wireless Hinge Replacement: 步骤 2 中的图像 1,3 Beats Studio3 Wireless Hinge Replacement: 步骤 2 中的图像 2,3 Beats Studio3 Wireless Hinge Replacement: 步骤 2 中的图像 3,3
      • You can also use your hands to remove it completely.
      • Pulling it off can be challenging; make sure to apply enough pressure.
      询问修复机器人
      添加评论
    1. Beats Studio3 Wireless Hinge Replacement, Left Driver Assembly: 步骤 3 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement, Left Driver Assembly: 步骤 3 中的图像 2,2
      • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
      • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
      • Open the speaker by pulling the top layer of the speaker.
      询问修复机器人
      添加评论
    2. Beats Studio3 Wireless Hinge Replacement: 步骤 4 中的图像 1,3 Beats Studio3 Wireless Hinge Replacement: 步骤 4 中的图像 2,3 Beats Studio3 Wireless Hinge Replacement: 步骤 4 中的图像 3,3
      • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
      • Use a nylon spudger to remove the glue.
      • Pull on the wire to remove it while also removing the blue rubber band.
      询问修复机器人
      添加评论
    3. Beats Studio3 Wireless Hinge Replacement: 步骤 5 中的图像 1,3 Beats Studio3 Wireless Hinge Replacement: 步骤 5 中的图像 2,3 Beats Studio3 Wireless Hinge Replacement: 步骤 5 中的图像 3,3
      • Using a soldering iron to remove the cables on the charger port.
      • For help with soldering, check out the How to Solder and Desolder Connections guide.
      • Remove the two wires connected in the middle of the speaker using a soldering iron.
      • Remove the speaker from the headset.
      询问修复机器人
      添加评论
    1. Beats Studio3 Wireless Hinge Replacement, Battery: 步骤 6 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement, Battery: 步骤 6 中的图像 2,2
      • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
      • Be gentle while removing this piece as it is glued on with adhesive.
      询问修复机器人
      添加评论
    2. Beats Studio3 Wireless Hinge Replacement: 步骤 7 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement: 步骤 7 中的图像 2,2
      • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    3. Beats Studio3 Wireless Hinge Replacement: 步骤 8 中的图像 1,3 Beats Studio3 Wireless Hinge Replacement: 步骤 8 中的图像 2,3 Beats Studio3 Wireless Hinge Replacement: 步骤 8 中的图像 3,3
      • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
      • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
      • The panel will pop open after separating.
      询问修复机器人
      添加评论
    4. Beats Studio3 Wireless Hinge Replacement: 步骤 9 中的图像 1,1
      • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
      • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
      询问修复机器人
      添加评论
    5. Beats Studio3 Wireless Hinge Replacement: 步骤 10 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement: 步骤 10 中的图像 2,2
      • Use a nylon spudger to lift up the glue sticking the wires down.
      • Use a nylon spudger to lift the connector to disconnect the battery.
      添加评论
    1. Beats Studio3 Wireless Hinge Replacement, Hinge: 步骤 11 中的图像 1,3 Beats Studio3 Wireless Hinge Replacement, Hinge: 步骤 11 中的图像 2,3 Beats Studio3 Wireless Hinge Replacement, Hinge: 步骤 11 中的图像 3,3
      • Pull the wire making sure that the blue rubber band is off.
      • Heat the glue holding the wires down with a hair dryer or heat gun until the glue softens.
      • Make sure not to overheat any device part, which could cause damage to the sound.
      • With a pointed nylon spudger, remove the glue.
      询问修复机器人
      添加评论
    2. Beats Studio3 Wireless Hinge Replacement: 步骤 12 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement: 步骤 12 中的图像 2,2
      询问修复机器人
      添加评论
    3. Beats Studio3 Wireless Hinge Replacement: 步骤 13 中的图像 1,3 Beats Studio3 Wireless Hinge Replacement: 步骤 13 中的图像 2,3 Beats Studio3 Wireless Hinge Replacement: 步骤 13 中的图像 3,3
      • With a hair dryer or heating gun, heat the glue that is sticking the wires down.
      • Use a nylon spudger to remove the softened glue.
      • Remove the circular tape inside of the ear pad.
      询问修复机器人
      添加评论
    4. Beats Studio3 Wireless Hinge Replacement: 步骤 14 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement: 步骤 14 中的图像 2,2
      • Remove the single 3.5 mm screw with a Phillips #0 screwdriver.
      • Pull apart the top layer of the earpiece.
      询问修复机器人
      添加评论
    5. Beats Studio3 Wireless Hinge Replacement: 步骤 15 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement: 步骤 15 中的图像 2,2
      • Remove the tape holding the wires in place.
      • Pull the wires through the hole with your hand.
      询问修复机器人
      添加评论
    6. Beats Studio3 Wireless Hinge Replacement: 步骤 16 中的图像 1,1
      • Bend the hinge and remove the two 3.5 mm screws with a Phillips #0 screwdriver.
      添加评论
    7. Beats Studio3 Wireless Hinge Replacement: 步骤 17 中的图像 1,3 Beats Studio3 Wireless Hinge Replacement: 步骤 17 中的图像 2,3 Beats Studio3 Wireless Hinge Replacement: 步骤 17 中的图像 3,3
      • Pull the hinge down.
      • Pull on the wires one at a time making sure you don't damage them.
      询问修复机器人
      添加评论
    8. Beats Studio3 Wireless Hinge Replacement: 步骤 18 中的图像 1,2 Beats Studio3 Wireless Hinge Replacement: 步骤 18 中的图像 2,2
      在这个步骤中使用的工具:
      • With tweezers, remove the pin located inside of the hinge.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G4
3 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 67
过去 30 天: 249
总计 11,001
