跳转到主内容
加入维修社区 - 创建账户
Battery Disconnection
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnection, Heat the rear glass: 步骤 1 中的图像 1,1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 1,3 Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 2,3 Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 3,3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Battery Disconnection, Slice the adhesive: 步骤 3 中的图像 1,2 Battery Disconnection, Slice the adhesive: 步骤 3 中的图像 2,2
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Battery Disconnection, Slice the adhesive: 步骤 4 中的图像 1,3 Battery Disconnection, Slice the adhesive: 步骤 4 中的图像 2,3 Battery Disconnection, Slice the adhesive: 步骤 4 中的图像 3,3
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Battery Disconnection: 步骤 5 中的图像 1,3 Battery Disconnection: 步骤 5 中的图像 2,3 Battery Disconnection: 步骤 5 中的图像 3,3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Battery Disconnection: 步骤 6 中的图像 1,3 Battery Disconnection: 步骤 6 中的图像 2,3 Battery Disconnection: 步骤 6 中的图像 3,3
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Battery Disconnection: 步骤 7 中的图像 1,3 Battery Disconnection: 步骤 7 中的图像 2,3 Battery Disconnection: 步骤 7 中的图像 3,3
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
  8. Battery Disconnection, Remove the rear glass: 步骤 8 中的图像 1,2 Battery Disconnection, Remove the rear glass: 步骤 8 中的图像 2,2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Battery Disconnection, Unfasten the motherboard cover screws: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the eleven 3.8 mm-long screws securing the motherboard cover.
    • One of the screws is hidden beneath an orange sticker.
  10. Battery Disconnection, Pry up the motherboard cover: 步骤 10 中的图像 1,2 Battery Disconnection, Pry up the motherboard cover: 步骤 10 中的图像 2,2
    • Insert the tip of an opening pick underneath the right edge of the motherboard cover.
    • Twist the opening pick sideways to pry up the motherboard cover.
  11. Battery Disconnection, Remove the motherboard cover: 步骤 11 中的图像 1,2 Battery Disconnection, Remove the motherboard cover: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Use your fingers or a pair of tweezers to remove the motherboard cover.
  12. Battery Disconnection, Disconnect the battery cable: 步骤 12 中的图像 1,2 Battery Disconnection, Disconnect the battery cable: 步骤 12 中的图像 2,2
    • Use a spudger to disconnect the battery flex cable by prying the connector straight up from its socket.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Manuel Haeussermann
于07/13/22注册
23,152 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,906篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 67
