跳转到主内容
加入维修社区 - 创建账户
Basic Maintenance
你所需要的
  1. Basic Maintenance, Locating the side panel: 步骤 1 中的图像 1,2 Basic Maintenance, Locating the side panel: 步骤 1 中的图像 2,2
    • First, locate the side panel on the far left side of your board.
    • Then, flip your board upside down.
    • Make sure your console is resting on a towel or soft surface, as hard jolts or bumps can cause damage to your board.
    询问修复机器人
    添加评论
  2. Basic Maintenance, Removing the bracket: 步骤 2 中的图像 1,2 Basic Maintenance, Removing the bracket: 步骤 2 中的图像 2,2
    • Now, use your Phillips-head screwdriver to unscrew the two screws holding the bracket on.
    • Then flip your board over and do the same on the other side to remove the second bracket.
    询问修复机器人
    添加评论
  3. Basic Maintenance, Loosening the panel screws: 步骤 3 中的图像 1,1
    • Now, locate the three screws at the bottom of the back panel and loosen them approximately two full turns.
    • Make sure to keep screws separate! Always label and separate different screws to avoid confusion when we reassemble the board.
    询问修复机器人
    添加评论
  4. Basic Maintenance, Remove the metal pieces: 步骤 4 中的图像 1,1
    • Now flip your board over again so it is right-side-up.
    • Then, remove the seven screws holding the metal piece on with the same screwdriver. There is one screw to the far right of the piece that I could not fit into the photo.
    询问修复机器人
    添加评论
  5. Basic Maintenance, Pull the top off: 步骤 5 中的图像 1,2 Basic Maintenance, Pull the top off: 步骤 5 中的图像 2,2
    • Now, put your hand on the back of the board and lift up and away from the base of the console. Be careful of any wires!
    • Set the top panel next to the base to avoid wires getting tangled and broken.
    询问修复机器人
    添加评论
  6. Basic Maintenance, The inside components: 步骤 6 中的图像 1,2 Basic Maintenance, The inside components: 步骤 6 中的图像 2,2
    • You might notice that a lot of the components inside the lighting board look similar to those of a desktop computer. The power supply, hard drive, RAM, CPU, and cooling system are all in the base of the board.
    • If you have a compressed air can or blower, use that to clean the main components, especially around the CPU and heatsinks, as these can get clogged with dust and debris. If you don't have one of these tools, use a DRY paper towel or tissue to gently wipe down the components.
    询问修复机器人
    添加评论
  7. Basic Maintenance, Re-seating the RAM: 步骤 7 中的图像 1,2 Basic Maintenance, Re-seating the RAM: 步骤 7 中的图像 2,2
    • RAM is good to re-seat every so often, as it helps to maintain clean ports and fast memory speeds.
    • To remove the RAM, press down on the two clips on either side of the stick, then pull up on the RAM to remove it.
    • Once you remove it, you can take your air blower and gently blow off any dust on the connectors and memory cards.
    询问修复机器人
    添加评论
    • Now reverse these steps to reassemble your ETC Ion 1000!
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
someperson
于02/11/26注册
953 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 83
