跳转到主内容
加入维修社区 - 创建账户
Axess TA2513-10WT Camera Replacement
你所需要的
    1. Axess TA2513-10WT Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
      询问修复机器人
      添加评论
    2. Axess TA2513-10WT Camera Replacement: 步骤 2 中的图像 1,3 Axess TA2513-10WT Camera Replacement: 步骤 2 中的图像 2,3 Axess TA2513-10WT Camera Replacement: 步骤 2 中的图像 3,3
      • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
      • Slide the plastic opening tool gently along the sides.
      • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
      询问修复机器人
      添加评论
    3. Axess TA2513-10WT Camera Replacement: 步骤 3 中的图像 1,1
      • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
      询问修复机器人
      添加评论
    4. Axess TA2513-10WT Camera Replacement: 步骤 4 中的图像 1,1
      • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
      询问修复机器人
      添加评论
    1. Axess TA2513-10WT Camera Replacement, Camera: 步骤 5 中的图像 1,1
      • Turn the tablet over. Locate the left screw.
      • Use the magnetic screwdriver to remove the left screw.
      询问修复机器人
      添加评论
    2. Axess TA2513-10WT Camera Replacement: 步骤 6 中的图像 1,1
      • There is a bottom screw located to the right of the left screw that was just removed.
      • Remove the bottom screw using the magnetic screwdriver.
      询问修复机器人
      添加评论
    3. Axess TA2513-10WT Camera Replacement: 步骤 7 中的图像 1,1
      在这个步骤中使用的工具:
      • Remove the entire plastic cover using either tweezers or your fingers.
      询问修复机器人
      添加评论
    4. Axess TA2513-10WT Camera Replacement: 步骤 8 中的图像 1,1
      • Brush the surfaces of the cameras to remove any debris that is present.
      询问修复机器人
      添加评论
    5. Axess TA2513-10WT Camera Replacement: 步骤 9 中的图像 1,1
      • There is a black plastic cover on the back of the tablet. It is attached to the ribbon cable.
      • Use tweezers to rotate the black plastic cover 90 degrees upwards.
      • Flip the cover up and pull out the ribbon cable.
      询问修复机器人
      添加评论
    6. Axess TA2513-10WT Camera Replacement: 步骤 10 中的图像 1,1
      • Remove the ribbon cable from the port.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Steven Kavanagh
于03/24/15注册
301 声望
创作了3篇指南
团队
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 的会员
BU-SHAVER-S15S6G3
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 29
总计 514
