跳转到主内容
Asus Zenbook UX32VD  HD Web Camera Replacement
Michael Remmel
Michael Remmel 另一个贡献者
最后更新于 December 28, 2015
1小时
中等
If the HD web camera is not functioning this guide will teach you how to get behind the screen cover to replace the camera.
Note: Be sure the camera is broken and not just a software issue before you replace it.
你所需要的
工具
查看更多...
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: 步骤 1 中的图像 1,1
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 2 中的图像 1,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 2 中的图像 2,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 2 中的图像 3,3
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 3 中的图像 1,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 3 中的图像 2,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 3 中的图像 3,3
    • Remove display screen frame completely before adhesive cools and hardens.
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 4 中的图像 1,2 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 4 中的图像 2,2
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 5 中的图像 1,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 5 中的图像 2,3 Asus Zenbook UX32VD  HD Web Camera Replacement: 步骤 5 中的图像 3,3
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
结论
Michael Remmel
于09/17/15注册
718 声望
创作了3篇指南
团队
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S2G2
4 名成员
创作了6篇指南
2指南评论
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - 回复
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 1,976
