跳转到主内容
加入维修社区 - 创建账户
Asus X551CA Battery Replacement
你所需要的
  1. Asus X551CA Battery Replacement, Keyboard Plate Cover: 步骤 1 中的图像 1,1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    添加评论
  2. Asus X551CA Battery Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    询问修复机器人
    添加评论
  3. Asus X551CA Battery Replacement: 步骤 3 中的图像 1,1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    询问修复机器人
    添加评论
  4. Asus X551CA Battery Replacement: 步骤 4 中的图像 1,3 Asus X551CA Battery Replacement: 步骤 4 中的图像 2,3 Asus X551CA Battery Replacement: 步骤 4 中的图像 3,3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    添加评论
  5. Asus X551CA Battery Replacement: 步骤 5 中的图像 1,1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    添加评论
  6. Asus X551CA Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
    添加评论
结论
取消:我没有完成这个指南。
58等其他人完成本指南。
Josh
于04/10/14注册
2,970 声望
创作了12篇指南
团队
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G22
5 名成员
创作了15篇指南
11指南评论
Thank you for the procedure. I never worked with ribbon connectors like that; perhaps a few words or pictures that shows connecting procedures may be helpful to others. How far in ribbon must be etc. Thanks again, good job.
tiggy13 - 回复 分享
Thank you very much for your guide
ramsugu - 回复 分享
Hi there! I have replaced my battery but the new one does not charge. Does anyone have any idea on how to solve it? I have tried several possible solutions found online like removing the battery (completely) turning on the CPU and then off, placed the battery and restarted. Pressing the power button for 15s or 60s and then turn on the CPU.... well.... Loosing hope here.... :( Help!
fpchaves - 回复 分享
The only thing I can think of is that the new battery was faulty. It is probably way too late to return it, but you could try buying another and see if the same problem recurs with the new, new one.
Albert Einstein - 回复 分享
Thank you, Josh. Clear instructions. The most difficult part for me was to re-connect the "ribbons", since I don't have nimble fingers. I actually used a plastic toothpick to help doing this :)
Ben Lam - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 67
总计 73,118
