Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement
简介
转到步骤 1This guide will walk you through the steps to replace a dead or non-working microphone in an Asus Tablet MeMo Pad 7 ME700C. Make sure you are using the proper tools and exercising caution while opening the back panel to avoid causing damage to the tablet.
你所需要的
Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
在这个步骤中使用的工具:Tweezers$4.99
Disconnect the microphone plug from the motherboard.
Use the tweezers to gently pull the white plug from the motherboard.
