跳转到主内容
加入维修社区 - 创建账户
Asus ROG G20CB Graphics Card Replacement
你所需要的
    1. Asus ROG G20CB Graphics Card Replacement, Fan: 步骤 1 中的图像 1,2 Asus ROG G20CB Graphics Card Replacement, Fan: 步骤 1 中的图像 2,2
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      询问修复机器人
      添加评论
    2. Asus ROG G20CB Graphics Card Replacement: 步骤 2 中的图像 1,1
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      询问修复机器人
      添加评论
    3. Asus ROG G20CB Graphics Card Replacement: 步骤 3 中的图像 1,1
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      询问修复机器人
      添加评论
    4. Asus ROG G20CB Graphics Card Replacement: 步骤 4 中的图像 1,1
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      询问修复机器人
      添加评论
    5. Asus ROG G20CB Graphics Card Replacement: 步骤 5 中的图像 1,1
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      询问修复机器人
      添加评论
    6. Asus ROG G20CB Graphics Card Replacement: 步骤 6 中的图像 1,1
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      询问修复机器人
      添加评论
    1. Asus ROG G20CB Graphics Card Replacement, Graphics Card: 步骤 7 中的图像 1,1
      • Remove the three 4.6 mm Phillips screws from the graphics card housing.
      询问修复机器人
      添加评论
    2. Asus ROG G20CB Graphics Card Replacement: 步骤 8 中的图像 1,1
      • Pull the graphics card housing out of the case.
      • Be mindful of the 8-pin power cable connected to the graphics card.
      询问修复机器人
      添加评论
    3. Asus ROG G20CB Graphics Card Replacement: 步骤 9 中的图像 1,1
      • Push down the clip on the red cable connector and firmly pull the cable from the graphics card.
      询问修复机器人
      添加评论
    4. Asus ROG G20CB Graphics Card Replacement: 步骤 10 中的图像 1,1
      • Remove the 3.7 mm Phillips screw from the graphics card and its housing.
      询问修复机器人
      添加评论
    5. Asus ROG G20CB Graphics Card Replacement: 步骤 11 中的图像 1,1
      • Slide the graphics card out of the housing.
      询问修复机器人
      添加评论
    6. Asus ROG G20CB Graphics Card Replacement: 步骤 12 中的图像 1,1
      • Use one hand to bend up the PCIE riser clip, then with the other hand push it off the graphics card.
      • This riser will need to be used with the new graphics card in order to be installed in this system.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
AdamGadd
于03/21/25注册
349 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-3, Botvin Spring 2025 UMass Dartmouth, Team 3-3, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S3G3
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 60
总计 622
