跳转到主内容
Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
Nejad Harara
Nejad Harara6 其他贡献者
最后更新于 May 7, 2024
20分钟
中等
This guide will take you through the necessary steps to disassemble your Asus MeMO Pad 7 ME176C to replace the screen.
你所需要的
工具
查看更多...
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: 步骤 1 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: 步骤 1 中的图像 2,2
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 2 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 5 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 5 中的图像 2,2
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 6 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 6 中的图像 2,2
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 7 中的图像 1,3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 7 中的图像 2,3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 7 中的图像 3,3
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 8 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 8 中的图像 2,2
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 9 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 9 中的图像 2,2
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 10 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 10 中的图像 2,2
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 11 中的图像 1,2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 11 中的图像 2,2
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 12 中的图像 1,3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 12 中的图像 2,3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 步骤 12 中的图像 3,3
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
结论
Nejad Harara
于09/26/17注册
110 声望
撰写一个指南
团队
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G3
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 1,830
