跳转到主内容
Asus MeMO Pad 7 ME170C  Microphone  Replacement
Tatiana Schneider
Tatiana Schneider8 其他贡献者
最后更新于 May 7, 2024
7分钟
中等
需要更好的图片
The microphone is where you input sound, as opposed to the speaker which is what outputs sound. This is where you record voice memos, give commands to a built in operating system, or voice to text functions.
你所需要的
工具
查看更多...
  1. Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: 步骤 1 中的图像 1,3 Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: 步骤 1 中的图像 2,3 Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: 步骤 1 中的图像 3,3
    • Before beginning to dissemble, power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Using the Jimmy tool, gently wedge it into the seam of the device.
    • Gently pry the Jimmy tool all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Microphone  Replacement: 步骤 2 中的图像 1,3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: 步骤 2 中的图像 2,3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: 步骤 2 中的图像 3,3
    • Inserted in a black port on the motherboard, locate the white cable connector on the left side of the tablet.
    • In a side to side motion, using the smallest opening tool, slide the white cable box completely out of the port towards the bottom of the device.
  3. Asus MeMO Pad 7 ME170C  Microphone  Replacement: 步骤 3 中的图像 1,2 Asus MeMO Pad 7 ME170C  Microphone  Replacement: 步骤 3 中的图像 2,2
    • Pull the wire out of its tracking panel gently.
    • Note: This wire should be fairly easy to pull out of the panel.
  4. Asus MeMO Pad 7 ME170C  Microphone  Replacement: 步骤 4 中的图像 1,3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: 步骤 4 中的图像 2,3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Note: The end of the wire is attached to a small taped black box.
    • Using wide nosed tweezers, lift up the tape and remove from black box.
    • Note: Black box will loosen up once the tape is removed.
    • Remove the component completely from the device.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 1,056
