跳转到主内容
Asus Chromebook C523N Keyboard Replacement
Aaron Hogan
Aaron Hogan4 其他贡献者
最后更新于 January 3, 2020
30分钟
中等
需要更好的图片
If keys on the keyboard stick or are unresponsive when pressed for the Asus Chromebook C523N, use this guide to replace your keyboard. Before starting this guide, make certain that the Chromebook is not connected to power and is powered off.
你所需要的
工具
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Nylon Tipped Tweezers
查看更多...
  1. Asus Chromebook C523N Keyboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Keyboard Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 2 中的图像 2,2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Keyboard Replacement: 步骤 3 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Keyboard Replacement, Speaker: 步骤 4 中的图像 1,3 Asus Chromebook C523N Keyboard Replacement, Speaker: 步骤 4 中的图像 2,3 Asus Chromebook C523N Keyboard Replacement, Speaker: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Keyboard Replacement: 步骤 5 中的图像 1,3 Asus Chromebook C523N Keyboard Replacement: 步骤 5 中的图像 2,3 Asus Chromebook C523N Keyboard Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Keyboard Replacement: 步骤 6 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Keyboard Replacement: 步骤 7 中的图像 1,1
    • Gently grab both speakers and lift them from the Chromebook to remove.
  8. Asus Chromebook C523N Keyboard Replacement, Battery: 步骤 8 中的图像 1,3 Asus Chromebook C523N Keyboard Replacement, Battery: 步骤 8 中的图像 2,3 Asus Chromebook C523N Keyboard Replacement, Battery: 步骤 8 中的图像 3,3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  9. Asus Chromebook C523N Keyboard Replacement: 步骤 9 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 9 中的图像 2,2
    • Remove six 1.4 mm JIS #00 screws from the battery.
  10. Asus Chromebook C523N Keyboard Replacement: 步骤 10 中的图像 1,1
    • Remove the battery from the laptop.
  11. Asus Chromebook C523N Keyboard Replacement, Motherboard: 步骤 11 中的图像 1,3 Asus Chromebook C523N Keyboard Replacement, Motherboard: 步骤 11 中的图像 2,3 Asus Chromebook C523N Keyboard Replacement, Motherboard: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers, gently pry the black and white wires from the wireless card and lift.
  12. Asus Chromebook C523N Keyboard Replacement: 步骤 12 中的图像 1,3 Asus Chromebook C523N Keyboard Replacement: 步骤 12 中的图像 2,3 Asus Chromebook C523N Keyboard Replacement: 步骤 12 中的图像 3,3
    • Gently pull the trackpad cable from the connector, located next to the wireless card.
  13. Asus Chromebook C523N Keyboard Replacement: 步骤 13 中的图像 1,3 Asus Chromebook C523N Keyboard Replacement: 步骤 13 中的图像 2,3 Asus Chromebook C523N Keyboard Replacement: 步骤 13 中的图像 3,3
    • Using a spudger, disconnect the two side-by-side ribbon cables from their connectors, pushing in the direction of the ribbons (toward the left side of the Chromebook).
  14. Asus Chromebook C523N Keyboard Replacement: 步骤 14 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 14 中的图像 2,2
    • Disconnect the thick blue ribbon cable from the connector by pulling it away from the motherboard.
  15. Asus Chromebook C523N Keyboard Replacement: 步骤 15 中的图像 1,3 Asus Chromebook C523N Keyboard Replacement: 步骤 15 中的图像 2,3 Asus Chromebook C523N Keyboard Replacement: 步骤 15 中的图像 3,3
    • Remove the 0.4mm JIS #0 screws from the heat sink in the center of the motherboard.
    • Lift and remove the heat sink.
  16. Asus Chromebook C523N Keyboard Replacement: 步骤 16 中的图像 1,3 Asus Chromebook C523N Keyboard Replacement: 步骤 16 中的图像 2,3 Asus Chromebook C523N Keyboard Replacement: 步骤 16 中的图像 3,3
    • Gripping the thin white ribbon cable, gently pull it away from the motherboard to disconnect.
  17. Asus Chromebook C523N Keyboard Replacement: 步骤 17 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 17 中的图像 2,2
    • Disconnect the thick black connector by gently pulling it up, away from the motherboard.
  18. Asus Chromebook C523N Keyboard Replacement: 步骤 18 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 18 中的图像 2,2
    • Remove the two 0.4mm JIS #00 screws at the bottom of the hinge (closest to the motherboard).
    • Using an opening tool, pry the hinge upward.
  19. Asus Chromebook C523N Keyboard Replacement: 步骤 19 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 19 中的图像 2,2
    • Remove the two 0.4 mm JIS #00 screws from the motherboard.
    • Gently lift and remove the motherboard.
  20. Asus Chromebook C523N Keyboard Replacement, Touchpad: 步骤 20 中的图像 1,1
    • Pull gently on the touchpad cable connector to disconnect.
  21. Asus Chromebook C523N Keyboard Replacement: 步骤 21 中的图像 1,1
    • Carefully, remove the tape from the touch pad only.
  22. Asus Chromebook C523N Keyboard Replacement: 步骤 22 中的图像 1,1
    • Remove the three 1.4 mm JIS #00 screws.
  23. Asus Chromebook C523N Keyboard Replacement: 步骤 23 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement: 步骤 23 中的图像 2,2
    • Lift at the far edge of the touchpad to remove it.
  24. Asus Chromebook C523N Keyboard Replacement, Keyboard: 步骤 24 中的图像 1,2 Asus Chromebook C523N Keyboard Replacement, Keyboard: 步骤 24 中的图像 2,2
    • Disconnect the two ribbon cables from the daughterboard.
  25. Asus Chromebook C523N Keyboard Replacement: 步骤 25 中的图像 1,1
    • Remove the four 0.4mm JIS #00 screws from the daughterboard.
    • Remove the daughterboard.
  26. Asus Chromebook C523N Keyboard Replacement: 步骤 26 中的图像 1,1
    • Remove the two 0.4mm JIS #00 screws on the left hinge.
  27. Asus Chromebook C523N Keyboard Replacement: 步骤 27 中的图像 1,1
    • Lift the keyboard of the Chromebook off of the screen.
结论
2等其他人完成本指南。
3指南评论
Great walk through. I used this to replace a keyboard on a C423N ASUS. Everything but the track pad connector on the mother board and three screws instead of 2 on the screen hinges is the same.
Charles Stanley - 回复
Hi there
How would I replace the screen for this model??
Saif - 回复
how to replace ssd in motherbord
Suresh dhakar - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 13
总计 2,435
