跳转到主内容
Asus Chromebook C300SA-DS02 WiFi Card Replacement
Sarah Westberg
Sarah Westberg 另一个贡献者
最后更新于 May 6, 2019
30 - 40 分钟
中等
If your Asus Chromebook C300SA-DS02 WiFi card has been damaged, use this guide to replace it. Prior to replacing the wireless card, you will need to remove the back cover and keyboard and disconnect the battery for safety.
你所需要的
工具
  1. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 2 中的图像 1,3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 2 中的图像 2,3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 2 中的图像 3,3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 3 中的图像 3,3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: 步骤 5 中的图像 1,2 Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 6 中的图像 1,2 Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 6 中的图像 2,2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 7 中的图像 1,1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: 步骤 8 中的图像 1,3 Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: 步骤 8 中的图像 2,3 Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: 步骤 8 中的图像 3,3
    • Use the spudger to pop the black and white coaxial WiFi cables up from the WiFi card.
  9. Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 9 中的图像 1,2 Asus Chromebook C300SA-DS02 WiFi Card Replacement: 步骤 9 中的图像 2,2
    • Remove the one 3.6mm Phillips #0 screw from the WiFi card.
    • Pull and lift the WiFi card away from the motherboard.
结论
另外一个人完成了本指南。
Sarah Westberg
于03/11/19注册
29,645 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,552篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 444
