跳转到主内容
Asus Chromebook C300SA-DS02 LED Screen Replacement
Celina Monteiro
Celina Monteiro5 其他贡献者
最后更新于 December 10, 2019
15分钟
简单
This guide will walk you through the step by step process of removing the LED screen from the laptop. Screen removal is a multistep process that will require you to keep track of the parts taken out of the laptop. Each screw is accounted for in the steps they are removed.
你所需要的
工具
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 2 中的图像 1,3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 2 中的图像 2,3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 2 中的图像 3,3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 3 中的图像 3,3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: 步骤 5 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 6 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 6 中的图像 2,2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 7 中的图像 1,1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: 步骤 8 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: 步骤 8 中的图像 2,2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 9 中的图像 1,1
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 10 中的图像 1,1
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 11 中的图像 1,1
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 12 中的图像 1,1
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 14 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 14 中的图像 2,2
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
结论
2等其他人完成本指南。
Celina Monteiro
于10/17/17注册
233 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 UMass Dartmouth, Team S1-G7, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G7
3 名成员
创作了9篇指南
1指南评论
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 730
