跳转到主内容
Asus Chromebook C300SA- DS02 Keyboard Replacement
Lewis Shabshelowitz
Lewis Shabshelowitz5 其他贡献者
最后更新于 December 9, 2019
2分钟
简单
This guide will show how to open the laptop and remove the keyboard panel from the device. Note that this guide does not provide assistance to defective individual keys. The keyboard panel includes every key, the trackpad and the associated wires.
你所需要的
工具
  1. Asus Chromebook C300SA- DS02 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus Chromebook C300SA- DS02 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA- DS02 Keyboard Replacement: 步骤 2 中的图像 1,3 Asus Chromebook C300SA- DS02 Keyboard Replacement: 步骤 2 中的图像 2,3 Asus Chromebook C300SA- DS02 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA- DS02 Keyboard Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300SA- DS02 Keyboard Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300SA- DS02 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA- DS02 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard from the laptop.
结论
团队
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 UMass Dartmouth, Team S1-G7, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G7
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 519
