跳转到主内容
Asus Chromebook C300MA-DH02 Motherboard Replacement
Giang Le Nam Dang
Giang Le Nam Dang3 其他贡献者
最后更新于 December 8, 2019
15分钟
中等
需要更多图片
The motherboard is the most important part of your devise. It is responsible of everything ranging from basic processing to complex programs.
你所需要的
配件
工具
查看更多...
  1. Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 1,3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 2,3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 3,3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 3 中的图像 1,2 Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
    • Remove the motherboard silver mount.
  5. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to remove the connection from sound driver on the bottom left of the motherboard.
  6. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Gently remove the blue connector to the right side of the motherboard.
  7. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 7 中的图像 1,2 Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the Phillips #000 Screwdriver to remove the screw on right side of wireless card.
    • Remove the wireless card.
  8. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Start by lifting tape up off of the connection. Remove the connection to display.
  9. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 9 中的图像 1,3 Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 9 中的图像 2,3 Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove (3) three "4mm" screws that connect the hinge to the motherboard using the Phillips #000 Screwdriver.
    • Remove (5) five "4mm" screws around two sides of motherboard using the Phillips #000 Screwdriver.
  10. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Gently remove motherboard from the Asus Chromebook.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S6-G4, Remmell Fall 2017 USF Tampa, Team S6-G4, Remmell Fall 2017 的会员
USFT-REMMELL-F17S6G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 292
