Asus Chromebook C202 Wireless Card Replacement
简介
转到步骤 1Is the wireless connection to your Chromebook not working? Did you rule out any software-related solutions? If so, then you should replace your wireless card.
Remove Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
Ten 8 mm screws
Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
在这个步骤中使用的工具:iFixit Opening Tool$1.99
Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
