跳转到主内容
Asus Chromebook C101P Touchpad Replacement
Bryan Acosta
Bryan Acosta3 其他贡献者
最后更新于 May 7, 2024
10分钟
简单
Replacing the Asus Chromebook C101P touchpad is a simple procedure, so if you ever spill liquid onto your touchpad and it refuses to work anymore, don’t be scared. With just a few steps, you’ll be able to have a functioning touchpad again. It is important that you unplug and shut your Chromebook off before attempting this replacement in order to prevent electrocuting yourself.
你所需要的
工具
查看更多...
  1. Asus Chromebook C101P Touchpad Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Touchpad Replacement: 步骤 2 中的图像 1,1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Touchpad Replacement: 步骤 3 中的图像 1,1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Touchpad Replacement: 步骤 4 中的图像 1,2 Asus Chromebook C101P Touchpad Replacement: 步骤 4 中的图像 2,2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Touchpad Replacement: 步骤 5 中的图像 1,3 Asus Chromebook C101P Touchpad Replacement: 步骤 5 中的图像 2,3 Asus Chromebook C101P Touchpad Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,3 Asus Chromebook C101P Touchpad Replacement, Touchpad: 步骤 6 中的图像 2,3 Asus Chromebook C101P Touchpad Replacement, Touchpad: 步骤 6 中的图像 3,3
    • Remove the three Phillips #0 screws holding the trackpad in place.
  7. Asus Chromebook C101P Touchpad Replacement: 步骤 7 中的图像 1,3 Asus Chromebook C101P Touchpad Replacement: 步骤 7 中的图像 2,3 Asus Chromebook C101P Touchpad Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers, pull the cable free from the touchpad.
    • Using tweezers, pry off the tape holding the touchpad down.
结论
Bryan Acosta
于10/25/19注册
377 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G2
2 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 441
