跳转到主内容
Asus Chromebook C101P Speakers Replacement
Bryan Acosta
Bryan Acosta3 其他贡献者
最后更新于 May 7, 2024
10分钟
简单
With the Asus Chromebook C101P, you might need to replace your speakers if you have audio issues and nothing seems to fix it. Luckily, these speakers are very easy to replace, since they are out in the open and not tucked behind places like the motherboard. It is important that you unplug and shut your Chromebook off before attempting this replacement in order to prevent electrocuting yourself.
你所需要的
工具
查看更多...
  1. Asus Chromebook C101P Speakers Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Speakers Replacement: 步骤 2 中的图像 1,1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Speakers Replacement: 步骤 4 中的图像 1,2 Asus Chromebook C101P Speakers Replacement: 步骤 4 中的图像 2,2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Speakers Replacement: 步骤 5 中的图像 1,3 Asus Chromebook C101P Speakers Replacement: 步骤 5 中的图像 2,3 Asus Chromebook C101P Speakers Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Speakers Replacement, Speakers: 步骤 6 中的图像 1,1
    • Remove the four Phillips #0 screws from the speakers.
  7. Asus Chromebook C101P Speakers Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the yellow speaker tape using tweezers.
  8. Asus Chromebook C101P Speakers Replacement: 步骤 8 中的图像 1,2 Asus Chromebook C101P Speakers Replacement: 步骤 8 中的图像 2,2
    • Detach the right speaker using tweezers.
    • The right speaker has its own set of cables connecting to the motherboard. Simply tug on the cables.
结论
Bryan Acosta
于10/25/19注册
365 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G2
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 11
总计 456
