跳转到主内容
加入维修社区 - 创建账户
Asus CM1745 Hard Drive Replacement
你所需要的
    1. Asus CM1745 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Asus CM1745 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
      • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
      • Remember to unplug the device before beginning disassembly, to make sure that no power is running through the device during repair. You could risk hurting yourself and/or damage sensitive components.
      询问修复机器人
      添加评论
    2. Asus CM1745 Hard Drive Replacement: 步骤 2 中的图像 1,2 Asus CM1745 Hard Drive Replacement: 步骤 2 中的图像 2,2
      • Remove the two cables from the rear of the Hard Drive.
      • Unscrew the two screws attached to the Hard Drive with a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    3. Asus CM1745 Hard Drive Replacement: 步骤 3 中的图像 1,3 Asus CM1745 Hard Drive Replacement: 步骤 3 中的图像 2,3 Asus CM1745 Hard Drive Replacement: 步骤 3 中的图像 3,3
      • Flip the computer over and remove the sidepanel on that side.
      • Remove the Phillips #0 screw(s) attached to the Hard Drive on this side.
      • Once removed, slide the Hard Drive out the back. Remember the orientation that the Hard Drive was in.
      询问修复机器人
      添加评论
    4. Asus CM1745 Hard Drive Replacement: 步骤 4 中的图像 1,3 Asus CM1745 Hard Drive Replacement: 步骤 4 中的图像 2,3 Asus CM1745 Hard Drive Replacement: 步骤 4 中的图像 3,3
      • Take your replacement Hard Drive (Picture does not necessarily represent the exact Hard Drive) and place it in the same slot as the old one.
      • Replace the two screws on the front of the cage and the screw(s) on the back.
      • Replace the power and data cables on the back of the hard drive.
      询问修复机器人
      添加评论
结论
If everything looks to be in the right place, you should be able to boot the computer and boot into the BIOS to check if the Hard Drive is recognized. You will have to install a new Windows installation if this Hard Drive was your only Hard Drive.
取消:我没有完成这个指南。
2等其他人完成本指南。
TC Fowlar
于10/30/19注册
896 声望
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 71
总计 4,499
