跳转到主内容
加入维修社区 - 创建账户
Arlo Pro 2 Camera Micro-USB Port Replacement
你所需要的
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: 步骤 1 中的图像 1,3 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: 步骤 1 中的图像 2,3 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: 步骤 1 中的图像 3,3
      • Press the release button on the camera and gently pull apart the casing to open the device.
      • Remove the battery from inside the case.
      询问修复机器人
      添加评论
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 2 中的图像 1,3 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 2 中的图像 2,3 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 2 中的图像 3,3
      • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
      • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
      询问修复机器人
      添加评论
    3. Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 3 中的图像 1,3 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 3 中的图像 2,3 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 3 中的图像 3,3
      • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
      • Seperate the daughterboards from the motherboard and camera casing.
      询问修复机器人
      添加评论
    4. Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 4 中的图像 1,3 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 4 中的图像 2,3 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 4 中的图像 3,3
      • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
      • Carefully pull the motherboard apart from the camera casing.
      询问修复机器人
      添加评论
    5. Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 5 中的图像 1,2 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 5 中的图像 2,2
      • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
      询问修复机器人
      添加评论
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: 步骤 6 中的图像 1,2 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: 步骤 6 中的图像 2,2
      • Thread the wires of the Micro-USB port through the casing.
      • Guide the wiring through the opening so that the wiring is solely in the battery cavity and not going through any part of the case.
      询问修复机器人
      添加评论
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 7 中的图像 1,3 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 7 中的图像 2,3 Arlo Pro 2 Camera Micro-USB Port Replacement: 步骤 7 中的图像 3,3
      • Use a Phillips #00 screwdriver to remove two 3 mm screws connecting the Micro-USB port to the camera casing.
      • Gently remove the Micro-USB port by pulling it away from the case.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
Ben I.
于03/26/25注册
493 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-2, Botvin Spring 2025 UMass Dartmouth, Team 2-2, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S2G2
3 名成员
创作了50篇指南
1指南评论
Great guide, I was able to remove the Micro USB Charge Port and Cable from the arlo PRO 2 (Model: VMC4030P) without having to remove the System Board. However finding a replacement part is the tricky part. I stumbled across this guide after removing the cable hoping an iFixIt guide might have a link to a part source.
tech2life - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 57
总计 416
