跳转到主内容
加入维修社区 - 创建账户
Arlo Pro 2 Camera Lens Replacement
你所需要的
    1. Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: 步骤 1 中的图像 1,3 Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: 步骤 1 中的图像 2,3 Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: 步骤 1 中的图像 3,3
      • Press the release button on the camera and gently pull apart the casing to open the device.
      • Remove the battery from inside the case.
      询问修复机器人
      添加评论
    2. Arlo Pro 2 Camera Lens Replacement: 步骤 2 中的图像 1,3 Arlo Pro 2 Camera Lens Replacement: 步骤 2 中的图像 2,3 Arlo Pro 2 Camera Lens Replacement: 步骤 2 中的图像 3,3
      • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
      • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
      询问修复机器人
      添加评论
    3. Arlo Pro 2 Camera Lens Replacement: 步骤 3 中的图像 1,3 Arlo Pro 2 Camera Lens Replacement: 步骤 3 中的图像 2,3 Arlo Pro 2 Camera Lens Replacement: 步骤 3 中的图像 3,3
      • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
      • Seperate the daughterboards from the motherboard and camera casing.
      询问修复机器人
      添加评论
    4. Arlo Pro 2 Camera Lens Replacement: 步骤 4 中的图像 1,3 Arlo Pro 2 Camera Lens Replacement: 步骤 4 中的图像 2,3 Arlo Pro 2 Camera Lens Replacement: 步骤 4 中的图像 3,3
      • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
      • Carefully pull the motherboard apart from the camera casing.
      询问修复机器人
      添加评论
    5. Arlo Pro 2 Camera Lens Replacement: 步骤 5 中的图像 1,2 Arlo Pro 2 Camera Lens Replacement: 步骤 5 中的图像 2,2
      • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
      询问修复机器人
      添加评论
    1. Arlo Pro 2 Camera Lens Replacement, Camera Lens: 步骤 6 中的图像 1,2 Arlo Pro 2 Camera Lens Replacement, Camera Lens: 步骤 6 中的图像 2,2
      • Use a Philips #00 screwdriver to remove the four 4 mm screws on the back metal plate holding the daughterboards together.
      询问修复机器人
      添加评论
    2. Arlo Pro 2 Camera Lens Replacement: 步骤 7 中的图像 1,2 Arlo Pro 2 Camera Lens Replacement: 步骤 7 中的图像 2,2
      • Slide out a small metal retainer bracket from in between the daughterboards.
      询问修复机器人
      添加评论
    3. Arlo Pro 2 Camera Lens Replacement: 步骤 8 中的图像 1,2 Arlo Pro 2 Camera Lens Replacement: 步骤 8 中的图像 2,2
      • Pull apart the daughterboard containing LEDs from the other daughterboard.
      询问修复机器人
      添加评论
    4. Arlo Pro 2 Camera Lens Replacement: 步骤 9 中的图像 1,2 Arlo Pro 2 Camera Lens Replacement: 步骤 9 中的图像 2,2
      • Separate the daughterboard containing the camera piece from the metal backing.
      询问修复机器人
      添加评论
    5. Arlo Pro 2 Camera Lens Replacement: 步骤 10 中的图像 1,3 Arlo Pro 2 Camera Lens Replacement: 步骤 10 中的图像 2,3 Arlo Pro 2 Camera Lens Replacement: 步骤 10 中的图像 3,3
      • Use a Philips #00 screwdriver to remove the two 5 mm screws on the back of the camera daughterboard to disconnect the camera piece from the daughterboard.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
Ben I.
于03/26/25注册
493 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-2, Botvin Spring 2025 UMass Dartmouth, Team 2-2, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S2G2
3 名成员
创作了40篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 373
