跳转到主内容
Apple Watch Ultra 2 Sensor Assembly Replacement
你所需要的
  1. Apple Watch Ultra 2 Sensor Assembly Replacement, Power down your watch: 步骤 1 中的图像 1,2 Apple Watch Ultra 2 Sensor Assembly Replacement, Power down your watch: 步骤 1 中的图像 2,2
    • Drain your watch battery below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Take your watch off the charger and power it down.
    • If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
  2. Apple Watch Ultra 2 Sensor Assembly Replacement, Safety details: 步骤 2 中的图像 1,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Safety details: 步骤 2 中的图像 2,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Safety details: 步骤 2 中的图像 3,3
    • Because the gap between the screen assembly and frame is so small, a thin metal tool is needed to pry the screen up. Read the following warnings before you start disassembly:
    • Protect your fingers by keeping them completely clear of the front end of your tool. You can protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the iFlex to slip and cut you, or damage the watch.
    • Wear eye protection. The glass may break, sending pieces flying.
    • Attach or remove the watch bands as needed to provide more control as you make repairs.
  3. Apple Watch Ultra 2 Sensor Assembly Replacement, Unfasten the sensor assembly screws: 步骤 3 中的图像 1,2 Apple Watch Ultra 2 Sensor Assembly Replacement, Unfasten the sensor assembly screws: 步骤 3 中的图像 2,2
    • Use a P5 Pentalobe driver to remove the four 2.2 mm‑long screws securing the sensor assembly.
  4. Apple Watch Ultra 2 Sensor Assembly Replacement, Soften the sensor assembly adhesive: 步骤 4 中的图像 1,1
    • Heat an iOpener and apply it to the sensor assembly for at least two minutes to loosen the adhesive underneath.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  5. Apple Watch Ultra 2 Sensor Assembly Replacement, Create a gap: 步骤 5 中的图像 1,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Create a gap: 步骤 5 中的图像 2,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Create a gap: 步骤 5 中的图像 3,3
    • Insert an iFlex in the seam between the watch frame and the top edge of the sensor assembly to create a gap.
    • Carefully twist the iFlex to widen the gap.
    • Don't apply too much force, or you'll cause the sensor assembly to pop off and tear the sensor assembly cables.
  6. Apple Watch Ultra 2 Sensor Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 1,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 2,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 3,3
    • Insert an opening pick into the gap you created.
    • Do not insert the opening pick deeper than 3 mm to avoid tearing the sensor assembly cables.
    • Remove the iFlex.
  7. Apple Watch Ultra 2 Sensor Assembly Replacement, Slice the sensor assembly adhesive: 步骤 7 中的图像 1,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Slice the sensor assembly adhesive: 步骤 7 中的图像 2,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Slice the sensor assembly adhesive: 步骤 7 中的图像 3,3
    • Slide the opening pick around the top right corner of the sensor assembly and along the right edge to slice its adhesive.
  8. Apple Watch Ultra 2 Sensor Assembly Replacement: 步骤 8 中的图像 1,2 Apple Watch Ultra 2 Sensor Assembly Replacement: 步骤 8 中的图像 2,2
    • Slide the opening pick around the bottom right corner and along the bottom edge to slice the rear assembly adhesive.
  9. Apple Watch Ultra 2 Sensor Assembly Replacement: 步骤 9 中的图像 1,2 Apple Watch Ultra 2 Sensor Assembly Replacement: 步骤 9 中的图像 2,2
    • Slide the opening around the bottom left corner and along the left edge to slice the remaining adhesive.
  10. Apple Watch Ultra 2 Sensor Assembly Replacement, Band release button information: 步骤 10 中的图像 1,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Band release button information: 步骤 10 中的图像 2,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Band release button information: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    • In the following steps, the band release buttons and springs may fall out. Be careful during the disassembly, as they are very easy to lose.
    • The band release buttons are equipped with a tiny spring on each end. The springs are mandatory for the buttons to function properly.
    • During reassembly, make sure each band release button has its two springs, and the buttons are repositioned in their recesses.
    • If a band release button falls out and the springs aren't on the button, they may have gotten stuck in the watch during disassembly. Use a pair of tweezers to remove them from the watch and place them upright into their recess on the button for reassembly.
  11. Apple Watch Ultra 2 Sensor Assembly Replacement, Lift the sensor assembly: 步骤 11 中的图像 1,2 Apple Watch Ultra 2 Sensor Assembly Replacement, Lift the sensor assembly: 步骤 11 中的图像 2,2
    • The sensor assembly is connected to the watch body with two cables. One of the cables is extremely short and its connector will automatically disconnect when lifting the sensor assembly.
    • To reconnect the short press connector during reassembly, line up the sensor assembly to the frame and squeeze gently.
    • Carefully lift the top edge of the sensor assembly with your opening pick until you can get a good grip with your fingers.
    • Don't try to remove the sensor assembly all the way yet. It's still connected to the watch body.
  12. Apple Watch Ultra 2 Sensor Assembly Replacement, Swing open the sensor assembly: 步骤 12 中的图像 1,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Swing open the sensor assembly: 步骤 12 中的图像 2,3 Apple Watch Ultra 2 Sensor Assembly Replacement, Swing open the sensor assembly: 步骤 12 中的图像 3,3
    • Be careful not to strain the sensor assembly cable when you lift the assembly up.
    • Lift the sensor assembly and carefully pull it towards the bottom edge of the watch.
    • Swing the sensor assembly open to an upward position.
  13. Apple Watch Ultra 2 Sensor Assembly Replacement, Disconnect the sensor assembly cable: 步骤 13 中的图像 1,2 Apple Watch Ultra 2 Sensor Assembly Replacement, Disconnect the sensor assembly cable: 步骤 13 中的图像 2,2
    • The band release button near the sensor assembly cable is equipped with a tiny spring on each end. Be careful not to lose the button or its springs.
    • Use a spudger to pry and disconnect the sensor assembly cable from its socket.
  14. Apple Watch Ultra 2 Sensor Assembly Replacement, Remove the sensor assembly: 步骤 14 中的图像 1,1
    • Remove the sensor assembly.
结论
Arthur Shi
于01/03/18注册
313,746 声望
创作了729篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,765篇指南
1指南评论
Nice job!
But where can I get a spare sensor assembly for the Ultra 2.
On iFixit it doesn't seem to be available
Would a rear side sensor assembly from an iCloud locked Ultra 2 watch, sometimes offered on eBay, work?
jojo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 28
过去 30 天: 127
总计 2,877
