简介
使用本指南来更换Apple Watch Series 5中的破旧或没电的电池。
本指南在手表的蜂窝/ LTE版本上显示了步骤,但是仅GPS版本是类似的。
如果电池膨胀,采取适当的预防措施。为了你的安全,在拆卸手表之前,请“使电池电量低于25%”。如果在维修过程中意外损坏了电池,则可以降低发生危险热事件的风险。
在Apple Watch的显示屏打开过程中,你可能会损坏强制触摸垫圈。如果分开垫片层或切断电缆,则还需要更换Force Touch垫片本身。
重新组装设备时,你需要更换粘合剂来重新连接组件。
你所需要的
如果可能,在安装新的胶粘剂和重新密封之前,请打开设备并测试维修情况。
[指南| 113604 |用预先切割的胶粘剂固定新电池| new_window = true]或双面胶带。为了正确放置它,请将新粘合剂涂在设备中旧粘合剂所在的位置,而不要直接涂在电池上。用力将新电池按入到位。
要重新组装设备,请按照逆序进行操作。用异丙醇(> 90%)清洁相关区域后,如有必要,请应用新的粘合剂。
为了获得最佳性能,请在完成本指南后校准新安装的电池。
将你的电子垃圾带到R2或e-Stewards认证回收商。
17等其他人完成本指南。
由衷感谢以下译者:
92%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
7条评论
Since WatchOS 7 removed 3D Touch functionality on all Force Touch enabled watches, will damaging or disconnecting the Force Touch gasket affect the functionality of the watch or will the software brick it?
Any tips for applying the adhesive strip without removing the screen? Is removing the screen recommended to seat it properly?
Does the resealing adhesive strip go in between the screen and force touch gasket, or the force touch gasket and the case?
Hi David,
here is a general resealing guide that might help you. Depending on your force touch replacement part you‘ll need one two or no adhesive strips.
If your force touch was never removed you need to place new adhesive on top of it the adhere the screen. If your force touch has adhesive on the bottom side it is the same. Adhere the force touch into the watch frame and place adhesive on top of it to adhere the screen. If there is adhesive on the top of the force touch you need to place the adhesive strip beneath.
If your force touch didn‘t come with any adhesive preinstalled you need adhesive tape below to secure it to the watch frame and on top to secure the screen.
Hi @schnabel , thank you for you reply. I am in the middle of replacing the battery. I managed to save the force touch sensor from getting damaged, but I need to be re-adhere it to both surfaces. Can I use 2 of these adhesive strips on either side?
Apple Watch (44 mm Series 4/5) Adhesive Strip
