简介
Use this guide to replace the worn out battery in your Apple Watch Series 1.
Note: If your battery is swollen, take appropriate precautions.
你所需要的
Before starting repairs, take your watch off the charger and power it down.
Prepare an iOpener (or grab a hair dryer or heat gun) and heat the face of the watch until it's slightly too hot to touch.
Leave the iOpener on the watch for at least a minute to fully heat the screen and soften the adhesive holding it to the case.
Place the curved section of the blade in the gap between the glass and case on the lower edge of the watch face, and press firmly straight down into the gap.
When the glass has lifted, gently rotate the knife down, opening the gap more by pushing the glass up.
Use scissors to cut one of your opening picks to about the width of the battery. Try not to leave any sharp corners.
Insert the modified pick between the right side of the battery and the case.
Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
On the larger (42 mm) models, it's possible to accidentally pry at the system board underneath the battery. Insert the pick only far enough to get underneath the battery, not the system board.
If needed, apply a little high concentration isopropyl alcohol (90% or greater) around and under the battery to help weaken the adhesive.
Continue from Step 17 of our Force Touch Sensor guide to re-seal your watch and complete your repair.
250等其他人完成本指南。
16条评论
Hi,
I am replacing a battery that swelled and pushed the screen up. This is the original Apple Watch it was working prior to replacing battery but only lasted a few hours. Got first battery and it didn’t do anything, retailer replaced it since it was a dud. New battery in and placed on charger and I got the snake charging symbol then nothing. When I try to force reset, shows white Apple logo and then disappears and does nothing. Help!? Thanks
Same!!!! The Apple logo comes up and then disappears when charging only??!!
Ditto.
I replaced the battery with a new battery and when charging, the Watch will display the Apple Logo for <1 second, and then be blank for a while.
Hi, i had the same problem. After changing the battery, firstly the watch has started. So i have let the watch until the battery was empty and charged it. After a night of charging trying to start the watch : green snake !
So i have let the watch during one week without recharging it. Then i have put the watch on the charger during 2 hours and the watch had started by itself and now all is ok.
luc poli -
Hello, I just replaced the battery on my Apple watch series 1 and have the same issue as some other were already facing while trying to charge the watch : the apple logo appears for few seconds and then disappear again and do the same continuously (sometimes it disappears in a red tainted color). I tried the hard reset, but it was unsuccessful. Does anybody have a solution to this issue ? Many thanks in advance for your help !
jforastier - 回复
