跳转到主内容
Apple Watch SE Watch Band Replacement
Destiny Holtzman
Destiny Holtzman 另一个贡献者
最后更新于 December 16, 2024
4分钟
中等
This guide will lead you through the steps of replacing an Apple Watch SE band. Replacing the watch band is a simple and affordable way to transform your device. This guide will walk you through the process, step-by-step, so you can effortlessly swap out your old band for a new one, or replace a broken one, and get back to enjoying your watch.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Apple Watch SE Watch Band Replacement, Watch Band: 步骤 1 中的图像 1,3 Apple Watch SE Watch Band Replacement, Watch Band: 步骤 1 中的图像 2,3 Apple Watch SE Watch Band Replacement, Watch Band: 步骤 1 中的图像 3,3
    • Turn off your device by holding down the side button until the slider appears.
    • Tap the Power button at the top right hand corner.
    • Slide the Power Off slider to the right.
  2. Apple Watch SE Watch Band Replacement: 步骤 2 中的图像 1,1
    • Lay your Apple Watch face down on a soft, clean surface to avoid scratching the screen.
  3. Apple Watch SE Watch Band Replacement: 步骤 3 中的图像 1,3 Apple Watch SE Watch Band Replacement: 步骤 3 中的图像 2,3 Apple Watch SE Watch Band Replacement: 步骤 3 中的图像 3,3
    • Hold down one of the release buttons on the back of the device, and slide out its corresponding band at the same time.
    • This may take some effort. If the band does not slide out, press down the release button again and make sure to hold it down.
  4. Apple Watch SE Watch Band Replacement: 步骤 4 中的图像 1,2 Apple Watch SE Watch Band Replacement: 步骤 4 中的图像 2,2
    • Repeat Step 3 with the other side of the band.
  5. Apple Watch SE Watch Band Replacement: 步骤 5 中的图像 1,2 Apple Watch SE Watch Band Replacement: 步骤 5 中的图像 2,2
    • Gently wipe any residue off of the back of the watch using a gentle towel, cotton swab, or cotton ball.
    • Do not use any abrasive chemicals.
  6. Apple Watch SE Watch Band Replacement: 步骤 6 中的图像 1,2 Apple Watch SE Watch Band Replacement: 步骤 6 中的图像 2,2
    • Take the new watch band and make sure the side of the band with metal connectors is facing the watch, and the correct orientation is followed.
  7. Apple Watch SE Watch Band Replacement: 步骤 7 中的图像 1,2 Apple Watch SE Watch Band Replacement: 步骤 7 中的图像 2,2
    • Gently slide the new band into the slot.
    • It will click into place when it is properly secured.
    • Repeat on the other side.
终点
另外一个人完成了本指南。
Destiny Holtzman
于10/04/24注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 28
总计 106
