简介
Use this guide to replace a broken, cracked, or defective display on your Apple Watch SE.
Replacing the display can cause issues with Apple Pay. If possible, to reduce the likelihood of problems, delete all your Apple Pay account info before the replacement, and then re-enter it with the new display installed.
You’ll need replacement adhesive to reattach components when reassembling the device.
你所需要的
Before starting repairs, take your watch off the charger and power it down.
If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
Press firmly straight down into the gap.
Once inserted, tilt the blade to pry the display open slightly.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the adhesive tape.
Alternatively, apply a little bit of high-concentration isopropyl alcohol (>90%) to a Q-tip and apply it to the black adhesive foil on top of the display connectors. Let it penetrate the adhesive for about two minutes.
Use a pair of tweezers to carefully peel off the tape covering the right display cable connector.
Use the pointed end of a spudger to open the right ZIF connector on the rear side of the display by bringing its flap in an upright position.
Use a pair of tweezers to peel the left edge off the display cable sticker off the rear side of the display.
Carefully pull the display flex cables out of their ZIF connectors.
To reassemble your Apple Watch SE follow these instructions in reverse order to reattach the screen and the battery.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
32等其他人完成本指南。
6条评论
any idea where I can purchase the replacement screen itself?
Will I be able to preserve the NFC antenna after replacing the screen?
