跳转到主内容
加入维修社区 - 创建账户
Apple Thunderbolt Display LCD Replacement
你所需要的
  1. Apple Thunderbolt Display LCD Replacement, LCD: 步骤 1 中的图像 1,3 Apple Thunderbolt Display LCD Replacement, LCD: 步骤 1 中的图像 2,3 Apple Thunderbolt Display LCD Replacement, LCD: 步骤 1 中的图像 3,3
    • Lay down the display with screen side up.
    • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
    • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
    • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
    添加评论
  2. Apple Thunderbolt Display LCD Replacement: 步骤 2 中的图像 1,2 Apple Thunderbolt Display LCD Replacement: 步骤 2 中的图像 2,2
    • Unscrew the 12 screws around the side edges and the top of the LCD with the TR 10 Screwdriver.
    添加评论
  3. Apple Thunderbolt Display LCD Replacement: 步骤 3 中的图像 1,2 Apple Thunderbolt Display LCD Replacement: 步骤 3 中的图像 2,2
    • Slowly lift the LCD out from its placement and tilt it upwards.
    • It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
    • There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
    添加评论
  4. Apple Thunderbolt Display LCD Replacement: 步骤 4 中的图像 1,3 Apple Thunderbolt Display LCD Replacement: 步骤 4 中的图像 2,3 Apple Thunderbolt Display LCD Replacement: 步骤 4 中的图像 3,3
    • For the first of the four wires (furthest away from the wire that is held in by a screw), grab onto the connector and pull slowly.
    添加评论
  5. Apple Thunderbolt Display LCD Replacement: 步骤 5 中的图像 1,3 Apple Thunderbolt Display LCD Replacement: 步骤 5 中的图像 2,3 Apple Thunderbolt Display LCD Replacement: 步骤 5 中的图像 3,3
    • For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
    • Flip the metal bar over using the tape as a handle.
    • Next, grab onto the connector and slowly pull it from the socket in the logic board.
    添加评论
  6. Apple Thunderbolt Display LCD Replacement: 步骤 6 中的图像 1,3 Apple Thunderbolt Display LCD Replacement: 步骤 6 中的图像 2,3 Apple Thunderbolt Display LCD Replacement: 步骤 6 中的图像 3,3
    • For the connector on the other side of the logic board, grab the connector from underneath and carefully pull it from the board.
    添加评论
  7. Apple Thunderbolt Display LCD Replacement: 步骤 7 中的图像 1,1
    • For the last wire connecting to the LCD, use your T 10 Screwdriver to remove the screw.
    询问修复机器人
    添加评论
  8. Apple Thunderbolt Display LCD Replacement: 步骤 8 中的图像 1,2 Apple Thunderbolt Display LCD Replacement: 步骤 8 中的图像 2,2
    • The LCD has now been fully disconnected from the casing and can be repaired/replaced!
    • its best to set the LCD on a bed or on a thick towel to avoid damage to the LCD
    添加评论
结论
取消:我没有完成这个指南。
30等其他人完成本指南。
团队
Cal Poly, Team 5-11, Maness Spring 2015 Cal Poly, Team 5-11, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G11
4 名成员
创作了20篇指南
13指南评论
Now I just need to find the affordable replacement LCD Panel. Mine is not too bad - but it has recently developed a streak on one side that is very irksome.
gigabob - 回复 分享
Love your site! Proved very helpful on multiple occasions and your products are fantastic!
Forgive my ignorance...
Is it possible to (1) Are any of the components of Thunderbolt Display upgrade-able? .... (2) There appears to be plenty of real-estate, can a Thunderbolt Display be turned into mac and/or pc? ... (3) Any way to upgrade to USB 3.0/3.1?...
I like tinkering with electronics and don't mind the complexities or if necessary getting parts, just wondering if any of these are possible and if so, can you give a clue as to where I can find more info... Thank You.
Mark Karasin - 回复 分享
Would like to see a continuation of what it takes to replace the Thunderbolt cable that is attached to the back of the display
Michael Martin - 回复 分享
Hi Michael
What happen to your monitor for you to need to replace the cable. It could be solution as to why my monitor has a black screen.
Any help?
Thanks
Fm34b - 回复 分享
Does the LCD from an iMac 2009 27” fit into the Thunderbolt Display and make it work?
Aldo B - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 224
总计 38,604
