简介
Are you experiencing noise distortion and reduced sound quality in your device? If so, follow this guide to help replace the driver in your Anker Soundcore Space One headphones.
A headphone driver is the transducer element responsible for converting electrical signals into sound waves. It typically consists of a diaphragm that moves to create sound, and it plays a crucial role in determining the overall sound quality of headphones. A failing driver can cause your device to have distorted or unbalanced sound, loss of bass response, and muffled sound in general.
Before using this guide, make sure to review the troubleshooting page about audio distortion. There could be many other easy-to-fix things in this device that don't require changing the driver.
你所需要的
Position the inside of the driver housing facing up (without the ear pad).
Unscrew the six 6.1 mm Phillips #00 screws from the driver housing.
Flip the popped-off plate component away from the ear cup.
Use a soldering iron in a circular path along with the seam of the glue (white lining) to separate the two components that are glued together.
Pop off this component once it has detached from the glue (a spudger may be needed for this).
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1指南评论
Unfortunately, the newer ones have the inner plate (the baffle) SEALED to the underlying frame. There is no spudge in the world that'll get it off without breaking it - I've tried and tried :-(
Tony Cafazzo - 回复 分享
