跳转到主内容
加入维修社区 - 创建账户
Anker Soundcore Motion 300 Drivers Replacement
你所需要的
  1. Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: 步骤 1 中的图像 1,2 Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: 步骤 1 中的图像 2,2
    • Insert an opening tool into a seam between the grille and chassis.
    • Gently pry the grille up to begin disengaging the retaining clip.
    • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
    询问修复机器人
    添加评论
  2. Anker Soundcore Motion 300 Drivers Replacement: 步骤 2 中的图像 1,2 Anker Soundcore Motion 300 Drivers Replacement: 步骤 2 中的图像 2,2
    • Keep working around the edges until all the clips are loose.
    • You may hear soft clicking sounds as the clips come undone.
    询问修复机器人
    添加评论
  3. Anker Soundcore Motion 300 Drivers Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the grille from the speaker.
    询问修复机器人
    添加评论
  4. Anker Soundcore Motion 300 Drivers Replacement, Drivers: 步骤 4 中的图像 1,3 Anker Soundcore Motion 300 Drivers Replacement, Drivers: 步骤 4 中的图像 2,3 Anker Soundcore Motion 300 Drivers Replacement, Drivers: 步骤 4 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
    询问修复机器人
    添加评论
  5. Anker Soundcore Motion 300 Drivers Replacement: 步骤 5 中的图像 1,3 Anker Soundcore Motion 300 Drivers Replacement: 步骤 5 中的图像 2,3 Anker Soundcore Motion 300 Drivers Replacement: 步骤 5 中的图像 3,3
    • Use an opening tool to pry up the speaker housing.
    • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
    • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
    询问修复机器人
    添加评论
  6. Anker Soundcore Motion 300 Drivers Replacement: 步骤 6 中的图像 1,3 Anker Soundcore Motion 300 Drivers Replacement: 步骤 6 中的图像 2,3 Anker Soundcore Motion 300 Drivers Replacement: 步骤 6 中的图像 3,3
    • With a Phillips #0 screwdriver, remove the four 7.5 mm screws that secure the driver.
    • Repeat the previous bullet for the other driver.
    • Gently lift off the drivers; the speakers may be slightly glued or stuck to the plastic plate so try not pull on the wiring attaching the components.
    • Disconnect each of the the two driver connectors from the motherboard.
    • There may be a small piece of sealant that must be removed before the connectors can be removed.
    • Remove the drivers.
    询问修复机器人
    添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 74
总计 596
