跳转到主内容
加入维修社区 - 创建账户
Anker SoundCore 2 Battery Replacement
你所需要的
  1. Anker SoundCore 2 Battery Replacement, Front Panel: 步骤 1 中的图像 1,2 Anker SoundCore 2 Battery Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
    添加评论
  2. Anker SoundCore 2 Battery Replacement, Battery: 步骤 2 中的图像 1,3 Anker SoundCore 2 Battery Replacement, Battery: 步骤 2 中的图像 2,3 Anker SoundCore 2 Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #1 screwdriver (Phillips #0 can strip the screw heads).
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Be careful not to damage the rubber gasket around the speaker mount plate.
    • Use your hand to remove the speakers. Some variants have a wire from the speaker to the board, some rest on contact pins.
    询问修复机器人
    添加评论
  3. Anker SoundCore 2 Battery Replacement: 步骤 3 中的图像 1,3 Anker SoundCore 2 Battery Replacement: 步骤 3 中的图像 2,3 Anker SoundCore 2 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #1 screwdriver. Some variants have 2 screws.
    • Carefully remove the bluetooth antenna wire from the left of the board. It pulls up without much pressure.
    • Flip up the motherboard to expose the battery.
    询问修复机器人
    添加评论
  4. Anker SoundCore 2 Battery Replacement: 步骤 4 中的图像 1,2 Anker SoundCore 2 Battery Replacement: 步骤 4 中的图像 2,2
    • Use a nylon spudger to remove the battery from the speaker casing.
    • Caution: Do not use metal prying tools on a battery—these can puncture an unprotected battery, potentially causing a fire.
    • The battery is glued down so it may be difficult to remove.
    询问修复机器人
    添加评论
  5. Anker SoundCore 2 Battery Replacement: 步骤 5 中的图像 1,2 Anker SoundCore 2 Battery Replacement: 步骤 5 中的图像 2,2
    • Unplug the wire that connects the battery with the motherboard.
    • Battery specs: 2 x 18650 2600mAh soldered in series (to bring voltage to 7.4V).
    • Can safely be upgraded to 2 x 18650 3500mAh for additional capacity.
    • When replacing the battery, plug in the new battery where the old one was plugged in.
    添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
8指南评论
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Michael Anderson - 回复 分享
7.2V, 2550 mAh, 18.36 Watt - Hour
Kang Le - 回复 分享
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
abdurreheembakir - 回复 分享
Akku SoundCore2
Kapazität 2600 mAh Leistung 19.24 Wh Spannung 7.4 V Typ Li-ion
Andreas Reheis - 回复 分享
same. i tried cleaning and drying, even an improvised other battery but nothing happens. charging only ever shows red light.
JohnLS17 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 143
过去 30 天: 717
总计 24,670
