跳转到主内容
加入维修社区 - 创建账户
Anker 2.4G Wireless Mouse Sensor Replacement
你所需要的
    1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: 步骤 1 中的图像 1,1
      • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
      询问修复机器人
      添加评论
    2. Anker 2.4G Wireless Mouse Sensor Replacement: 步骤 2 中的图像 1,1
      • Using your Phillips screwdriver, remove the four screws.
      询问修复机器人
      添加评论
    3. Anker 2.4G Wireless Mouse Sensor Replacement: 步骤 3 中的图像 1,2 Anker 2.4G Wireless Mouse Sensor Replacement: 步骤 3 中的图像 2,2
      • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
      • Make sure you are not using too much pressure, as you could warp the plastic.
      询问修复机器人
      添加评论
    4. Anker 2.4G Wireless Mouse Sensor Replacement: 步骤 4 中的图像 1,1
      • Disconnect the wires from the white crimping headers.
      • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
      询问修复机器人
      添加评论
    5. Anker 2.4G Wireless Mouse Sensor Replacement: 步骤 5 中的图像 1,1
      • Remove the scroll wheel from the motherboard by pulling it to the left.
      • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
      询问修复机器人
      添加评论
    6. Anker 2.4G Wireless Mouse Sensor Replacement: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      Anti-Static Wrist Strap
      $7.95
      • Gently lift the motherboard away from the plastic housing.
      • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
      询问修复机器人
      添加评论
    7. Anker 2.4G Wireless Mouse Sensor Replacement: 步骤 7 中的图像 1,1
      • Desolder the six wires holding the I.C. in place to complete the sensor change.
      • Replace the broken sensor with the new sensor and solder back in place.
      • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Ryan
于01/23/14注册
152 声望
撰写一个指南
团队
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G39
4 名成员
创作了48篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 56
总计 8,537
