跳转到主内容
加入维修社区 - 创建账户
Analogue Pocket Button Board Replacement
你所需要的
  1. Analogue Pocket Button Board Replacement, Prepare your device for disassembly: 步骤 1 中的图像 1,3 Analogue Pocket Button Board Replacement, Prepare your device for disassembly: 步骤 1 中的图像 2,3 Analogue Pocket Button Board Replacement, Prepare your device for disassembly: 步骤 1 中的图像 3,3
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
  2. Analogue Pocket Button Board Replacement, Unfasten the battery shell: 步骤 2 中的图像 1,2 Analogue Pocket Button Board Replacement, Unfasten the battery shell: 步骤 2 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Button Board Replacement, Remove the battery shell: 步骤 3 中的图像 1,3 Analogue Pocket Button Board Replacement, Remove the battery shell: 步骤 3 中的图像 2,3 Analogue Pocket Button Board Replacement, Remove the battery shell: 步骤 3 中的图像 3,3
  4. Analogue Pocket Button Board Replacement, Disconnect the battery: 步骤 4 中的图像 1,2 Analogue Pocket Button Board Replacement, Disconnect the battery: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Button Board Replacement, Remove the battery: 步骤 5 中的图像 1,3 Analogue Pocket Button Board Replacement, Remove the battery: 步骤 5 中的图像 2,3 Analogue Pocket Button Board Replacement, Remove the battery: 步骤 5 中的图像 3,3
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
  6. Analogue Pocket Button Board Replacement, Unclip the button board: 步骤 6 中的图像 1,3 Analogue Pocket Button Board Replacement, Unclip the button board: 步骤 6 中的图像 2,3 Analogue Pocket Button Board Replacement, Unclip the button board: 步骤 6 中的图像 3,3
    • A plastic clip secures the center of the button board.
    • Use the point of a spudger to push the clip out and release the board.
    • Don't try to remove the board—a delicate ribbon cable secures it to the device.
  7. Analogue Pocket Button Board Replacement, Reposition the button board: 步骤 7 中的图像 1,3 Analogue Pocket Button Board Replacement, Reposition the button board: 步骤 7 中的图像 2,3 Analogue Pocket Button Board Replacement, Reposition the button board: 步骤 7 中的图像 3,3
    • Swing the bottom edge of the button board up and over the cartridge reader.
    • Set the board on top of the cartridge reader so the cable's connector is facing the bottom of the device.
    • During reassembly:
    • Put the top edges of the board under their tabs on the rear shell.
    • Lay the board onto the rear shell so the alignment posts go into their circular cutouts on the board.
    • Press the board down until the plastic clip engages.
  8. Analogue Pocket Button Board Replacement, Disconnect the button board: 步骤 8 中的图像 1,3 Analogue Pocket Button Board Replacement, Disconnect the button board: 步骤 8 中的图像 2,3 Analogue Pocket Button Board Replacement, Disconnect the button board: 步骤 8 中的图像 3,3
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector located on the board itself.
    • Use blunt nose tweezers to pull the cable straight out of its socket.
  9. Analogue Pocket Button Board Replacement, Remove the board: 步骤 9 中的图像 1,2 Analogue Pocket Button Board Replacement, Remove the board: 步骤 9 中的图像 2,2
    • Remove the board.
  10. Analogue Pocket Button Board Replacement, Remove the old cable: 步骤 10 中的图像 1,3 Analogue Pocket Button Board Replacement, Remove the old cable: 步骤 10 中的图像 2,3 Analogue Pocket Button Board Replacement, Remove the old cable: 步骤 10 中的图像 3,3
    • If you suspect your board's cable is damaged, or your new board comes with a cable, follow the next three steps to remove the old one.
    • Sliding tabs secure the perimeter of the rear shell.
    • Firmly grip your device with one hand.
    • With your free hand, lift the bottom edge of the rear shell until it clears the front shell.
    • Pull the rear shell down until the sliding tabs disengage.
  11. Analogue Pocket Button Board Replacement: 步骤 11 中的图像 1,3 Analogue Pocket Button Board Replacement: 步骤 11 中的图像 2,3 Analogue Pocket Button Board Replacement: 步骤 11 中的图像 3,3
    • Remove the rear shell.
    • Thread the button board cable through its slot in the rear shell.
    • Lay the rear shell on the front shell so its bottom edge overhangs slightly.
    • This allows the tabs to slide into place. If the rear shell is perfectly flush with the front shell, the tabs won't slide.
    • Push the rear shell in and slide it up to engage the sliding tabs.
  12. Analogue Pocket Button Board Replacement: 步骤 12 中的图像 1,3 Analogue Pocket Button Board Replacement: 步骤 12 中的图像 2,3 Analogue Pocket Button Board Replacement: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector to the bottom left of the cartridge reader.
结论
Spencer Day
于09/14/22注册
161,258 声望
创作了1,045篇指南
团队
iFixit iFixit 的会员
Staff
125 名成员
创作了24,046篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 443
