跳转到主内容
Analogue Pocket Battery Cell Replacement
你所需要的
  1. Analogue Pocket Battery Cell Replacement, Prepare your device for disassembly: 步骤 1 中的图像 1,3 Analogue Pocket Battery Cell Replacement, Prepare your device for disassembly: 步骤 1 中的图像 2,3 Analogue Pocket Battery Cell Replacement, Prepare your device for disassembly: 步骤 1 中的图像 3,3
    • Allow your Analogue Pocket's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
  2. Analogue Pocket Battery Cell Replacement, Unfasten the battery shell: 步骤 2 中的图像 1,2 Analogue Pocket Battery Cell Replacement, Unfasten the battery shell: 步骤 2 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Battery Cell Replacement, Remove the battery shell: 步骤 3 中的图像 1,3 Analogue Pocket Battery Cell Replacement, Remove the battery shell: 步骤 3 中的图像 2,3 Analogue Pocket Battery Cell Replacement, Remove the battery shell: 步骤 3 中的图像 3,3
  4. Analogue Pocket Battery Cell Replacement, Disconnect the battery: 步骤 4 中的图像 1,2 Analogue Pocket Battery Cell Replacement, Disconnect the battery: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Battery Cell Replacement, Remove the battery: 步骤 5 中的图像 1,3 Analogue Pocket Battery Cell Replacement, Remove the battery: 步骤 5 中的图像 2,3 Analogue Pocket Battery Cell Replacement, Remove the battery: 步骤 5 中的图像 3,3
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
  6. Analogue Pocket Battery Cell Replacement, Heat the battery housing: 步骤 6 中的图像 1,3 Analogue Pocket Battery Cell Replacement, Heat the battery housing: 步骤 6 中的图像 2,3 Analogue Pocket Battery Cell Replacement, Heat the battery housing: 步骤 6 中的图像 3,3
    • Strong adhesive secures the battery cell to its housing.
    • Heat an iOpener and apply it to the top of the plastic battery housing for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer to lightly heat the housing. But be careful, as the plastic can easily be warped.
  7. Analogue Pocket Battery Cell Replacement, Separate the battery cell adhesive: 步骤 7 中的图像 1,3 Analogue Pocket Battery Cell Replacement, Separate the battery cell adhesive: 步骤 7 中的图像 2,3 Analogue Pocket Battery Cell Replacement, Separate the battery cell adhesive: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Take care not to bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Firmly secure the battery with one hand.
    • With your free hand, insert a plastic card between one of the long edges of the battery cell and its housing.
    • Pry up with the plastic card and apply steady pressure until a gap forms.
    • Be patient and allow plenty of time for the adhesive to separate. If you're having trouble creating a gap, apply more heat and try again.
    • Slide the card under the battery cell.
  8. Analogue Pocket Battery Cell Replacement: 步骤 8 中的图像 1,2 Analogue Pocket Battery Cell Replacement: 步骤 8 中的图像 2,2
    • Slide the plastic card back and forth under the battery cell to separate the adhesive.
  9. Analogue Pocket Battery Cell Replacement, Remove the battery: 步骤 9 中的图像 1,3 Analogue Pocket Battery Cell Replacement, Remove the battery: 步骤 9 中的图像 2,3 Analogue Pocket Battery Cell Replacement, Remove the battery: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    • Use the plastic card to lift the battery cell out of its housing and remove it.
    • During reassembly:
    • When installing a battery cell, make sure its cable goes into its cutout in the housing.
    • If your new battery cell comes with pre-installed adhesive, remove the plastic backing and firmly press the cell into place in its housing.
    • If your new battery cell doesn't have adhesive, use strips of double-sided tape such as Tesa Tape to secure it in the housing.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
于09/14/22注册
149,442 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,618篇指南
3指南评论
Where do I get the battery?
Ale Gan - 回复
I too would like to know the specs of the battery. Thank you.
PM1 Chicago - 回复
Here you go!
Model: 901-864974-011
Nominal Voltage: 3.7V
Rated Capacity: 4300mAh 15.91Wh
Spencer Day -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 23
过去 30 天: 103
总计 3,170
