跳转到主内容
Analogue Pocket Battery Replacement
你所需要的
  1. Analogue Pocket Battery Replacement, Prepare your device for disassembly: 步骤 1 中的图像 1,3 Analogue Pocket Battery Replacement, Prepare your device for disassembly: 步骤 1 中的图像 2,3 Analogue Pocket Battery Replacement, Prepare your device for disassembly: 步骤 1 中的图像 3,3
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
  2. Analogue Pocket Battery Replacement, Unfasten the battery shell: 步骤 2 中的图像 1,2 Analogue Pocket Battery Replacement, Unfasten the battery shell: 步骤 2 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Battery Replacement, Remove the battery shell: 步骤 3 中的图像 1,3 Analogue Pocket Battery Replacement, Remove the battery shell: 步骤 3 中的图像 2,3 Analogue Pocket Battery Replacement, Remove the battery shell: 步骤 3 中的图像 3,3
  4. Analogue Pocket Battery Replacement, Disconnect the battery: 步骤 4 中的图像 1,3 Analogue Pocket Battery Replacement, Disconnect the battery: 步骤 4 中的图像 2,3 Analogue Pocket Battery Replacement, Disconnect the battery: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Battery Replacement, Remove the battery: 步骤 5 中的图像 1,3 Analogue Pocket Battery Replacement, Remove the battery: 步骤 5 中的图像 2,3 Analogue Pocket Battery Replacement, Remove the battery: 步骤 5 中的图像 3,3
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
于09/14/22注册
59,632 声望
创作了430篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,858篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 34
过去 30 天: 120
总计 2,060
