跳转到主内容
加入维修社区 - 创建账户
Amazon Fire Max 11 Charging Port Replacement
你所需要的
    1. Amazon Fire Max 11 Charging Port Replacement, LCD Touch Screen: 步骤 1 中的图像 1,1
      • The heat gun can get very hot and can burn skin. If the device is heated for too long, it can be damaged.
      • Use a heat gun along the edges of the screen to loosen the adhesive.
      • Insert the iFixit opening tool along the seam between the screen and back case and gently pry around the perimeter of the screen.
      询问修复机器人
      添加评论
    2. Amazon Fire Max 11 Charging Port Replacement: 步骤 2 中的图像 1,2 Amazon Fire Max 11 Charging Port Replacement: 步骤 2 中的图像 2,2
      • Once the screen has been separated from the case, lift it slightly to reveal the display cable connected to the motherboard.
      • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
      • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
      • To reconnect:
      • Grip the cable and buckle together and insert the connector fully into its socket.
      • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
      • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
      • Remove the screen.
      询问修复机器人
      添加评论
    1. Amazon Fire Max 11 Charging Port Replacement, Charging Port: 步骤 3 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the two screws securing the bracket covering the charging port.
      • Remove the black bracket.
      • Use a spudger or a clean fingernail to flip up the locking flap—this is the unlocked position.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Once the flap is in the unlocked position, use tweezers or your fingers to gently pull the cable out of its socket by the brown tab.
      • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
      询问修复机器人
      添加评论
    2. Amazon Fire Max 11 Charging Port Replacement: 步骤 4 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the remaining two screws from the charging port.
      询问修复机器人
      添加评论
    3. Amazon Fire Max 11 Charging Port Replacement: 步骤 5 中的图像 1,2 Amazon Fire Max 11 Charging Port Replacement: 步骤 5 中的图像 2,2
      • Lift the charging port up slightly at an angle.
      • Disconnect the cable on the back of the board.
      • Slide the charging port out from the tablet.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 1-3, Konn Spring 2024 UMass Dartmouth, Team 1-3, Konn Spring 2024 的会员
UMASSD-KONN-S24S1G3
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 51
总计 1,079
