跳转到主内容
加入维修社区 - 创建账户
Amazon Fire HD 8 Screen Replacement
你所需要的
    1. Amazon Fire HD 8 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Amazon Fire HD 8 Screen Replacement, Screen: 步骤 1 中的图像 2,2
      • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
      • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
      询问修复机器人
      添加评论
    2. Amazon Fire HD 8 Screen Replacement: 步骤 2 中的图像 1,1
      • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
      • Be careful not to bend the screen by pushing it too far from the rest of the device.
      询问修复机器人
      添加评论
    3. Amazon Fire HD 8 Screen Replacement: 步骤 3 中的图像 1,3 Amazon Fire HD 8 Screen Replacement: 步骤 3 中的图像 2,3 Amazon Fire HD 8 Screen Replacement: 步骤 3 中的图像 3,3
      • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
      • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
      询问修复机器人
      添加评论
    4. Amazon Fire HD 8 Screen Replacement: 步骤 4 中的图像 1,3 Amazon Fire HD 8 Screen Replacement: 步骤 4 中的图像 2,3 Amazon Fire HD 8 Screen Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
      添加评论
结论
取消:我没有完成这个指南。
28等其他人完成本指南。
Dan Shimkus
于02/24/16注册
1,238 声望
创作了3篇指南
团队
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G3
4 名成员
创作了17篇指南
19指南评论
Thankyou so much!
Judie Buder @me.com - 回复 分享
Very nice, but even Amazon is not marketing the replacement screens.
Wendy Huntington Parker Fages - 回复 分享
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Kelsea Weber - 回复 分享
Fingers crossed Amazon offers more parts in the future! :)
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
Kitty Morgan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 60
过去 30 天: 219
总计 76,827
