跳转到主内容
加入维修社区 - 创建账户
Amazon Fire 5th Generation Motherboard Replacement
你所需要的
    1. Amazon Fire 5th Generation Motherboard Replacement, Speaker: 步骤 1 中的图像 1,2 Amazon Fire 5th Generation Motherboard Replacement, Speaker: 步骤 1 中的图像 2,2
      • Ensure that your device is turned off.
      • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
      • While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
      • Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
      • Then, remove the back cover from the device.
      询问修复机器人
      添加评论
    2. Amazon Fire 5th Generation Motherboard Replacement: 步骤 2 中的图像 1,2 Amazon Fire 5th Generation Motherboard Replacement: 步骤 2 中的图像 2,2
      • Pry the speaker from the case using the iFixit Opening Tool.
      • Lift the speaker up from the device to remove the speaker wires from their groove in the case.
      • Be careful not to pull the speaker wires from the motherboard.
      询问修复机器人
      添加评论
    3. Amazon Fire 5th Generation Motherboard Replacement: 步骤 3 中的图像 1,3 Amazon Fire 5th Generation Motherboard Replacement: 步骤 3 中的图像 2,3 Amazon Fire 5th Generation Motherboard Replacement: 步骤 3 中的图像 3,3
      • Desolder the speaker wires from the motherboard.
      • iFixit has a helpful guide explaining how to solder and desolder here: 如何焊接和拆焊
      添加评论
    1. Amazon Fire 5th Generation Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,3 Amazon Fire 5th Generation Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,3 Amazon Fire 5th Generation Motherboard Replacement, Motherboard: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • The battery connector is located in the upper left corner of the Amazon Fire battery pack.
      • To disconnect the battery connector, use angled ESD precision tweezers to lift the cables up and out of their socket.
      • Make sure you pull the battery connector cables themselves out and not the actual socket. Doing this step incorrectly could result in breaking the connector entirely.
      询问修复机器人
      添加评论
    2. Amazon Fire 5th Generation Motherboard Replacement: 步骤 5 中的图像 1,2 Amazon Fire 5th Generation Motherboard Replacement: 步骤 5 中的图像 2,2
      • Use a PH0 size Phillips screwdriver head to unscrew the five 2 mm screws on the motherboard. These screws are circled with red in the given image.
      • Ensure that you keep track of these screws once removed.
      添加评论
    3. Amazon Fire 5th Generation Motherboard Replacement: 步骤 6 中的图像 1,3 Amazon Fire 5th Generation Motherboard Replacement: 步骤 6 中的图像 2,3 Amazon Fire 5th Generation Motherboard Replacement: 步骤 6 中的图像 3,3
      • The LCD- Motherboard connector cable has a protective overlay that you must peel back with precision tweezers in order to expose the actual connector.
      • Gently pull down on the connector cable using precision tweezers in order to disconnect the cable.
      添加评论
      • The LCD Digitizer on the Amazon Fire tablet has a locking cable connector that holds it in place on the motherboard.
      • To remove the cable, use the iFixit Opening Tool to unlock the LCD Digitizer cable connector.
      • Once the wire connector is removed, use the iFixit Opening Tool to pry the entire LCD Digitizer away from the motherboard.
      • Remove any tape that may be covering the connector.
      询问修复机器人
      添加评论
      • The volume and power buttons must both be repositioned in order to remove the motherboard.
      • To reposition the power and volume buttons, use the iFixit Opening Tool to pull the plastic casing upwards. Then, remove the casing completely.
      • Make sure that both the volume and the power buttons are free from the plastic casing before separating the motherboard from its case.
      • Be very careful when repositioning the volume buttons, since the fragile digitizer ribbon cable runs from the motherboard to the digitizer right next to the volume buttons. It is very easy to damage the ribbon cable while working in this area.
      询问修复机器人
      添加评论
    4. Amazon Fire 5th Generation Motherboard Replacement: 步骤 9 中的图像 1,3 Amazon Fire 5th Generation Motherboard Replacement: 步骤 9 中的图像 2,3 Amazon Fire 5th Generation Motherboard Replacement: 步骤 9 中的图像 3,3
      • The rear facing camera wire connector must be disconnected in order to remove the motherboard.
      • To remove the rear facing wire connector, insert the iFixit Opening Tool beneath the connector and wedge it upwards.
      询问修复机器人
      添加评论
    5. Amazon Fire 5th Generation Motherboard Replacement: 步骤 10 中的图像 1,2 Amazon Fire 5th Generation Motherboard Replacement: 步骤 10 中的图像 2,2
      • Position the iFixit Opening Tool beneath the motherboard and pull upwards to remove the motherboard from its case.
      • Please handle the motherboard with gloves because skin oils can damage the connections on the board.
      添加评论
结论
取消:我没有完成这个指南。
22等其他人完成本指南。
Amber Bunch
于02/10/16注册
1,405 声望
创作了3篇指南
团队
USF Tampa, Team 1-2, Nance Spring 2016 USF Tampa, Team 1-2, Nance Spring 2016 的会员
USFT-NANCE-S16S1G2
3 名成员
创作了13篇指南
5指南评论
where can i get a motherboard from for a 5th gen 2015 ??
Dave Turnbull - 回复 分享
Great manual!!!!!!!
Roger Nelson - 回复 分享
Where is the hard drive? I need to replace that
Dylan Mitchell - 回复 分享
It doesn't use a hard drive, it has a flash chip underneath the big shield on the board which can be pried off with a screwdriver but to remove the chip you will need a heat gun.
Ellis Bowser - 回复 分享
Donde puedo conseguir ese touch de esa table
Yansel Tapia - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 79
总计 12,940
