跳转到主内容
加入维修社区 - 创建账户
Amazon Echo Look Wi-Fi Module Replacement
你所需要的
    1. Amazon Echo Look Wi-Fi Module Replacement, Front Panel: 步骤 1 中的图像 1,1
      • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
      询问修复机器人
      添加评论
    2. Amazon Echo Look Wi-Fi Module Replacement: 步骤 2 中的图像 1,3 Amazon Echo Look Wi-Fi Module Replacement: 步骤 2 中的图像 2,3 Amazon Echo Look Wi-Fi Module Replacement: 步骤 2 中的图像 3,3
      • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
      询问修复机器人
      添加评论
    3. Amazon Echo Look Wi-Fi Module Replacement: 步骤 3 中的图像 1,1
      • Heat the front panel with an iOpener.
      • It may help to secure the iOpener to the device.
      • Heat the device for 5-10 minutes to loosen the glue.
      • CAUTION: The iOpener and the device may be hot.
      询问修复机器人
      添加评论
    4. Amazon Echo Look Wi-Fi Module Replacement: 步骤 4 中的图像 1,3 Amazon Echo Look Wi-Fi Module Replacement: 步骤 4 中的图像 2,3 Amazon Echo Look Wi-Fi Module Replacement: 步骤 4 中的图像 3,3
      • Lever the Jimmy between the screen and the device until an opening is formed.
      • Insert opening picks to hold the opening as needed.
      • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
      • Step 3 may need to be repeated as Step 4 is time-sensitive.
      询问修复机器人
      添加评论
    5. Amazon Echo Look Wi-Fi Module Replacement: 步骤 5 中的图像 1,2 Amazon Echo Look Wi-Fi Module Replacement: 步骤 5 中的图像 2,2
      • Remove the front panel by levering the spudger at the top of the device.
      询问修复机器人
      添加评论
    1. Amazon Echo Look Wi-Fi Module Replacement, Midframe: 步骤 6 中的图像 1,2 Amazon Echo Look Wi-Fi Module Replacement, Midframe: 步骤 6 中的图像 2,2
      • Remove the screws from the midframe with a Torx T5 screwdriver.
      • Lift up the midframe
      • Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
      询问修复机器人
      添加评论
    2. Amazon Echo Look Wi-Fi Module Replacement: 步骤 7 中的图像 1,2 Amazon Echo Look Wi-Fi Module Replacement: 步骤 7 中的图像 2,2
      • Use a spudger to gently lift up the ribbon until it detaches.
      询问修复机器人
      添加评论
    1. Amazon Echo Look Wi-Fi Module Replacement, Wi-Fi Module: 步骤 8 中的图像 1,1
      • Use a spudger to pry the Wi-Fi module away from the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 469
