跳转到主内容
加入维修社区 - 创建账户
Altec Lansing inMotion iM9 Tweeter Replacement
你所需要的
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Battery: 步骤 1 中的图像 1,1
      • Gently push down on the two tabs at the top of the battery door.
      • While holding them down, slowly pull the door towards you.
      询问修复机器人
      添加评论
    2. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 2 中的图像 1,1
      • Once the door is open, use your hand to pull out the four batteries.
      询问修复机器人
      添加评论
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Volume and Power Buttons: 步骤 3 中的图像 1,2 Altec Lansing inMotion iM9 Tweeter Replacement, Volume and Power Buttons: 步骤 3 中的图像 2,2
      • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
      • Start in the middle and work your way around the perimeter.
      询问修复机器人
      添加评论
    2. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 4 中的图像 1,2 Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 4 中的图像 2,2
      • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
      • Also remove the single 7mm screw from the power button circuit board on the opposite side.
      • There will be a little plastic piece under the eject button that you can just remove and set aside.
      询问修复机器人
      添加评论
    3. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 5 中的图像 1,2 Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 5 中的图像 2,2
      • Desolder the three solders joints connecting the wires to the volume button circuit board.
      • Do the same to the power button circuit board on the other side (the board with only one screw).
      • Pull out the wires using a lot of force.
      • If you are not familiar or comfortable with soldering, use this guide
      询问修复机器人
      添加评论
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Case Opening: 步骤 6 中的图像 1,2 Altec Lansing inMotion iM9 Tweeter Replacement, Case Opening: 步骤 6 中的图像 2,2
      • Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
      • It is best to start from the top or bottom, then work your way around if it has not popped out yet.
      • Remove the silver lining.
      询问修复机器人
      添加评论
    2. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 7 中的图像 1,2 Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 7 中的图像 2,2
      • Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
      • Once loose, lift up the metal mesh.
      询问修复机器人
      添加评论
    3. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 8 中的图像 1,1
      • Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
      • Remove the 7mm screw with the Phillips #1 Screwdriver.
      询问修复机器人
      添加评论
    4. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 9 中的图像 1,1
      • Carefully separate the front and back case plates at a corner of the speaker.
      • Lots of cables are still connected, so be very gentle when separating case plates.
      询问修复机器人
      添加评论
    5. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 10 中的图像 1,1
      • Guide the white button cables through the hole on the top of speaker case.
      询问修复机器人
      添加评论
    6. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 11 中的图像 1,1
      • Use your fingers to peel the glue off of the red and black cables.
      询问修复机器人
      添加评论
    7. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 12 中的图像 1,1
      • Careful not to touch the green capacitors or you might shock yourself.
      询问修复机器人
      添加评论
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Tweeter: 步骤 13 中的图像 1,1
      • Remove the speaker cables by desoldering the two solder joints on opposite sides of the tweeter.
      询问修复机器人
      添加评论
    2. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 14 中的图像 1,1
      • To fully remove the tweeter from the device, unscrew the two 7mm screws and the tweeter will be free.
      询问修复机器人
      添加评论
    3. Altec Lansing inMotion iM9 Tweeter Replacement: 步骤 15 中的图像 1,1
      • Follow the previous instructions to remove the second tweeter on the opposite side of the speaker.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Shaun Steele
于02/02/15注册
279 声望
创作了2篇指南
团队
Cal Poly, Team 17-33, Amido Winter 2015 Cal Poly, Team 17-33, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G33
4 名成员
创作了63篇指南
1指南评论
Where do you buy the replacement tweeters?
Fred Schneider - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 30
总计 1,344
