简介
The Alldaymall A88X features a capacitive touch sensor that is mounted in front of the LCD Screen . This guide will walk you through the process of removing the existing touch sensor and installing a new one.
你所需要的
Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
After the battery is separated from the panel make sure to place it face down above the tablet itself.
在这个步骤中使用的工具:Tweezers$4.99
Use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
Using a pair of tweezers remove the ribbon cable from its receptacle.
Gently pry the brackets holding the touch sensor to the LCD Screen
2等其他人完成本指南。
