跳转到主内容
加入维修社区 - 创建账户
Alienware AW610M Side Button Replacement
你所需要的
    1. Alienware AW610M Side Button Replacement, Battery: 步骤 1 中的图像 1,3 Alienware AW610M Side Button Replacement, Battery: 步骤 1 中的图像 2,3 Alienware AW610M Side Button Replacement, Battery: 步骤 1 中的图像 3,3
      • Power off the mouse and disconnect any wired connections.
      询问修复机器人
      添加评论
    2. Alienware AW610M Side Button Replacement: 步骤 2 中的图像 1,2 Alienware AW610M Side Button Replacement: 步骤 2 中的图像 2,2
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      询问修复机器人
      添加评论
    3. Alienware AW610M Side Button Replacement: 步骤 3 中的图像 1,2 Alienware AW610M Side Button Replacement: 步骤 3 中的图像 2,2
      • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
      询问修复机器人
      添加评论
    4. Alienware AW610M Side Button Replacement: 步骤 4 中的图像 1,2 Alienware AW610M Side Button Replacement: 步骤 4 中的图像 2,2
      • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
      • Don't pull the halves completely apart, as internal wires still connect them.
      询问修复机器人
      添加评论
    5. Alienware AW610M Side Button Replacement: 步骤 5 中的图像 1,3 Alienware AW610M Side Button Replacement: 步骤 5 中的图像 2,3 Alienware AW610M Side Button Replacement: 步骤 5 中的图像 3,3
      • Remove the battery pack inside the mouse.
      • If you are having trouble, use a small flat tool to help ease it out.
      • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
      询问修复机器人
      添加评论
    6. Alienware AW610M Side Button Replacement: 步骤 6 中的图像 1,2 Alienware AW610M Side Button Replacement: 步骤 6 中的图像 2,2
      • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
      • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
      询问修复机器人
      添加评论
    1. Alienware AW610M Side Button Replacement, Side Button: 步骤 7 中的图像 1,2 Alienware AW610M Side Button Replacement, Side Button: 步骤 7 中的图像 2,2
      • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
      • Detach the cable connector, and remove the scroll wheel.
      • Gently detach the last connector using your fingers.
      • Be careful when unplugging all connectors to prevent tearing them.
      询问修复机器人
      添加评论
    2. Alienware AW610M Side Button Replacement: 步骤 8 中的图像 1,1
      • Turn the large shell casing so that the inside faces you.
      • Using a Phillips #1 screwdriver, remove six 5.4 mm screws.
      添加评论
    3. Alienware AW610M Side Button Replacement: 步骤 9 中的图像 1,2 Alienware AW610M Side Button Replacement: 步骤 9 中的图像 2,2
      • Using your fingers, disconnect the plastic tab in the middle of the large shell casing to access the side buttons.
      询问修复机器人
      添加评论
    4. Alienware AW610M Side Button Replacement: 步骤 10 中的图像 1,3 Alienware AW610M Side Button Replacement: 步骤 10 中的图像 2,3 Alienware AW610M Side Button Replacement: 步骤 10 中的图像 3,3
      • Remove the side button on the inner side of the wall using a plastic opening tool.
      • Be gentle prying the side buttons off to avoid breaking them.
      • When reassembling, position the new side button assembly into the slot, aligning it with tabs. Snap it securely into place using a plastic opening tool or your fingers.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Darby Brandt
于09/24/25注册
391 声望
创作了2篇指南
团队
Texas Tech, Team 46-4, Johansen Fall 2025 Texas Tech, Team 46-4, Johansen Fall 2025 的会员
TTU-JOHANSEN-F25S46G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 43
总计 257
