跳转到主内容
加入维修社区 - 创建账户
Alienware AW610M Mouse Feet Replacement
你所需要的
  1. Alienware AW610M Mouse Feet Replacement, Mouse Feet: 步骤 1 中的图像 1,3 Alienware AW610M Mouse Feet Replacement, Mouse Feet: 步骤 1 中的图像 2,3 Alienware AW610M Mouse Feet Replacement, Mouse Feet: 步骤 1 中的图像 3,3
    • Power off the mouse and disconnect any wired connections.
    询问修复机器人
    添加评论
  2. Alienware AW610M Mouse Feet Replacement: 步骤 2 中的图像 1,2 Alienware AW610M Mouse Feet Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to gently lift and remove the old mouse feet.
    • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
    • Be careful not to scratch the mouse surface or damage the plastic housing.
    询问修复机器人
    添加评论
  3. Alienware AW610M Mouse Feet Replacement: 步骤 3 中的图像 1,2 Alienware AW610M Mouse Feet Replacement: 步骤 3 中的图像 2,2
    • Take a lint free cloth lightly dampened and clean away any remaining adhesive residue.
    • Allow the surface to dry completely before applying new feet to ensure proper adhesion.
    询问修复机器人
    添加评论
  4. Alienware AW610M Mouse Feet Replacement: 步骤 4 中的图像 1,3 Alienware AW610M Mouse Feet Replacement: 步骤 4 中的图像 2,3 Alienware AW610M Mouse Feet Replacement: 步骤 4 中的图像 3,3
    • Peel the adhesive backing off the new mouse feet. Align the mouse foot with its designated area on the mouse. Press firmly to secure it in place. Repeat steps for bottom mouse foot.
    • Make sure the feet are properly aligned before pressing, as misalignment can affect mouse performance.
    询问修复机器人
    添加评论
  5. Alienware AW610M Mouse Feet Replacement: 步骤 5 中的图像 1,3 Alienware AW610M Mouse Feet Replacement: 步骤 5 中的图像 2,3 Alienware AW610M Mouse Feet Replacement: 步骤 5 中的图像 3,3
    • Power the mouse back on via wired or wireless connection and test the glide and tracking on a smooth surface.
    • If the mouse still tracks poorly, check the surface or sensor for dust or debris.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Ashley S.
于09/24/25注册
171 声望
撰写一个指南
团队
Texas Tech, Team 46-4, Johansen Fall 2025 Texas Tech, Team 46-4, Johansen Fall 2025 的会员
TTU-JOHANSEN-F25S46G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 64
总计 274
