跳转到主内容
加入维修社区 - 创建账户
Alienware AW610M Motherboard Replacement
你所需要的
    1. Alienware AW610M Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Alienware AW610M Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Alienware AW610M Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
      • Power off the mouse and disconnect any wired connections.
      询问修复机器人
      添加评论
    2. Alienware AW610M Motherboard Replacement: 步骤 2 中的图像 1,2 Alienware AW610M Motherboard Replacement: 步骤 2 中的图像 2,2
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      询问修复机器人
      添加评论
    3. Alienware AW610M Motherboard Replacement: 步骤 3 中的图像 1,2 Alienware AW610M Motherboard Replacement: 步骤 3 中的图像 2,2
      • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
      询问修复机器人
      添加评论
    4. Alienware AW610M Motherboard Replacement: 步骤 4 中的图像 1,2 Alienware AW610M Motherboard Replacement: 步骤 4 中的图像 2,2
      • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
      • Don't pull the halves completely apart, as internal wires still connect them.
      询问修复机器人
      添加评论
    5. Alienware AW610M Motherboard Replacement: 步骤 5 中的图像 1,3 Alienware AW610M Motherboard Replacement: 步骤 5 中的图像 2,3 Alienware AW610M Motherboard Replacement: 步骤 5 中的图像 3,3
      • Remove the battery pack inside the mouse.
      • If you are having trouble, use a small flat tool to help ease it out.
      • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
      询问修复机器人
      添加评论
    6. Alienware AW610M Motherboard Replacement: 步骤 6 中的图像 1,2 Alienware AW610M Motherboard Replacement: 步骤 6 中的图像 2,2
      • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
      • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
      询问修复机器人
      添加评论
    1. Alienware AW610M Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Alienware AW610M Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
      • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
      • Detach the cable connector, and remove the scroll wheel.
      • Gently detach the last connector using your fingers.
      • Be careful when unplugging all connectors to prevent tearing them.
      询问修复机器人
      添加评论
    2. Alienware AW610M Motherboard Replacement: 步骤 8 中的图像 1,2 Alienware AW610M Motherboard Replacement: 步骤 8 中的图像 2,2
      • Detach the blue ribbon that connects the motherboard to the shell casing.
      • Using a Phillips #1 screw driver, remove two 5.4 mm screws to detach the motherboard from the base shell casing.
      询问修复机器人
      添加评论
    3. Alienware AW610M Motherboard Replacement: 步骤 9 中的图像 1,3 Alienware AW610M Motherboard Replacement: 步骤 9 中的图像 2,3 Alienware AW610M Motherboard Replacement: 步骤 9 中的图像 3,3
      • Gently detach the motherboard using your fingers.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Sherlyn Herman
于09/24/25注册
97 声望
撰写一个指南
团队
Texas Tech, Team 46-4, Johansen Fall 2025 Texas Tech, Team 46-4, Johansen Fall 2025 的会员
TTU-JOHANSEN-F25S46G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 54
总计 347
