跳转到主内容
Alienware 17 R3 Battery Replacement
你所需要的
  1. Alienware 17 R3 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Battery Replacement: 步骤 2 中的图像 1,1
    • Unscrew and remove the two 4mm Phillips #1 screws from the cover.
    • Remember to put the screws in a safe place so you can find them all during re-assembly.
  3. Alienware 17 R3 Battery Replacement: 步骤 3 中的图像 1,1
    • Pull up and slide the cover off.
  4. Alienware 17 R3 Battery Replacement: 步骤 4 中的图像 1,2 Alienware 17 R3 Battery Replacement: 步骤 4 中的图像 2,2
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Battery Replacement: 步骤 5 中的图像 1,2 Alienware 17 R3 Battery Replacement: 步骤 5 中的图像 2,2
    • Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
  6. Alienware 17 R3 Battery Replacement: 步骤 6 中的图像 1,2 Alienware 17 R3 Battery Replacement: 步骤 6 中的图像 2,2
    • Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
  7. Alienware 17 R3 Battery Replacement: 步骤 7 中的图像 1,2 Alienware 17 R3 Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the plug from the hard drive.
    • Lift the hard drive out and set aside.
  8. Alienware 17 R3 Battery Replacement: 步骤 8 中的图像 1,1
    • Unscrew the one Phillips #1 screw holding down the bottom of the M.2 chip.
    • Pull the M.2 chip straight out of its socket.
  9. Alienware 17 R3 Battery Replacement: 步骤 9 中的图像 1,1
    • Unscrew and remove the eight 3mm Phillips #1 screws (located in areas labeled "P").
  10. Alienware 17 R3 Battery Replacement: 步骤 10 中的图像 1,1
    • Carefully disconnect the four flex cables.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  11. Alienware 17 R3 Battery Replacement: 步骤 11 中的图像 1,1
    • Remove the six 4mm Phillips #1 screws on the side and the two 10mm Phillips #1 screws on the top.
  12. Alienware 17 R3 Battery Replacement: 步骤 12 中的图像 1,1
    • Flip over the laptop and open it.
    • Insert the spudger along the edges of the laptop and gently pry upward to lift the keyboard panel.
  13. Alienware 17 R3 Battery Replacement: 步骤 13 中的图像 1,1
    • Remove the six 4mm Phillips #1 screws holding the battery in place.
  14. Alienware 17 R3 Battery Replacement: 步骤 14 中的图像 1,3 Alienware 17 R3 Battery Replacement: 步骤 14 中的图像 2,3 Alienware 17 R3 Battery Replacement: 步骤 14 中的图像 3,3
    • Unplug the two sets of wires from the motherboard.
  15. Alienware 17 R3 Battery Replacement: 步骤 15 中的图像 1,1
    • Lift out the battery pack.
结论
18等其他人完成本指南。
团队
UW Tacoma, Team 1-1, Rose Winter 2017 UW Tacoma, Team 1-1, Rose Winter 2017 的会员
UWT-ROSE-W17S1G1
3 名成员
创作了5篇指南
4条评论
Hi ! Nice DIY . Is it possible to disassemble the battery pack and change the cell inside ?
francois tremblay - 回复
Hi, please edit step 10. There a 4th ribbon has to be pulled.
Nevertheless a very good manual.
Steffen Bönisch - 回复
Hi Steffen,
Thanks for the tip! I edited step 10 to correct the mistake.
Arthur Shi -
Very helpful and concise. Worked very well for me. Many Thanks
Ragufta Khan - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 86
过去 30 天: 350
总计 29,695
