跳转到主内容
Alcatel OneTouch Elevate Rear Camera Replacement
Son Bao Luong
Son Bao Luong5 其他贡献者
最后更新于 February 26, 2025
20 - 40 分钟
中等
正在学习的学生
需要更好的图片
标记错误
缺少的步骤
更好的介绍
The guide on replacing motherboard is required before this guide. A faulty rare camera will not produce the ideal photo, and may not even be able to take a photo at all. If your Alcatel OneTouch Elevate’s rear camera is not functioning properly, this easy to follow guide will walk you through each step. Replacing the rear camera can improve issues like blurry or distorted images, or failure to capture photos. Replacing the camera is fairly straightforward, and does not require any special skills. Before beginning, make sure to power off your device and disconnect it from any power source.
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Alcatel OneTouch Elevate Rear Camera Replacement, Battery: 步骤 1 中的图像 1,3 Alcatel OneTouch Elevate Rear Camera Replacement, Battery: 步骤 1 中的图像 2,3 Alcatel OneTouch Elevate Rear Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 2 中的图像 1,3 Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 2 中的图像 2,3 Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 2 中的图像 3,3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate Rear Camera Replacement, Motherboard: 步骤 3 中的图像 1,3 Alcatel OneTouch Elevate Rear Camera Replacement, Motherboard: 步骤 3 中的图像 2,3 Alcatel OneTouch Elevate Rear Camera Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Using the Phillips screw driver, remove the 9 screws from the phone.
  4. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 4 中的图像 1,1
    • Using your prying tool, place it between the screen and the back cover and pry it open.
  5. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 5 中的图像 1,2 Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 5 中的图像 2,2
    • Disconnect the camera from the mother board with your prying tool.
  6. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 6 中的图像 1,3 Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 6 中的图像 2,3 Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 6 中的图像 3,3
    • Remove both of this cables located on the bottom left corner of the phone.
  7. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 7 中的图像 1,2 Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 7 中的图像 2,2
    • Remove the volume and power button using your prying tool.
    • Go underneath the bronze plate with your prying tool and carefully pry it off.
  8. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 8 中的图像 1,1
    • Remove this pice that is to the right of the camera with your prying tool.
  9. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 9 中的图像 1,2 Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove this two pieces by using your tweezers.
    • Carefully pull them off. There will be a black flap where you can place your tweezers to pull.
  10. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 10 中的图像 1,1
    • Using you prying tool, go in-between the phone.
    • Carefully pry it off.
  11. Alcatel OneTouch Elevate Rear Camera Replacement, Rear Camera: 步骤 11 中的图像 1,1
    • Find the camera and look for one of the corner where there is no border around the camera. (Red circle)
  12. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 12 中的图像 1,1
    • Gently put the opening tool head as close as possible to the edge, where the camera and the phone stick.
  13. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 13 中的图像 1,1
    • Flip the camera up carefully and slowly.
  14. Alcatel OneTouch Elevate Rear Camera Replacement: 步骤 14 中的图像 1,1
    • Put the old camera out and replace with the replacement.
    • Gently press on the camera and wait for it to stick back to the phone.
结论
Son Bao Luong
于02/08/18注册
109 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 174
