跳转到主内容
加入维修社区 - 创建账户
Alcatel 1B 2020 Screen Replacement
你所需要的
  1. Alcatel 1B 2020 Screen Replacement, Battery: 步骤 1 中的图像 1,3 Alcatel 1B 2020 Screen Replacement, Battery: 步骤 1 中的图像 2,3 Alcatel 1B 2020 Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • For your safety, unplug all peripherals, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Insert the opening tool into the seam between the back plastic case and the front screen.
    • Slide it around the edge of the phone to release the clips holding them together.
    • Remove the bottom case by hand.
    询问修复机器人
    添加评论
  2. Alcatel 1B 2020 Screen Replacement: 步骤 2 中的图像 1,3 Alcatel 1B 2020 Screen Replacement: 步骤 2 中的图像 2,3 Alcatel 1B 2020 Screen Replacement: 步骤 2 中的图像 3,3
    • Place the pry tool between the bottom of the battery and the bracket.
    • Lift the battery using the pry tool to remove it.
    询问修复机器人
    添加评论
  3. Alcatel 1B 2020 Screen Replacement, Rear Camera: 步骤 3 中的图像 1,3 Alcatel 1B 2020 Screen Replacement, Rear Camera: 步骤 3 中的图像 2,3 Alcatel 1B 2020 Screen Replacement, Rear Camera: 步骤 3 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove sixteen 3.0 mm screws that secure the black plastic bracket.
    询问修复机器人
    添加评论
  4. Alcatel 1B 2020 Screen Replacement: 步骤 4 中的图像 1,3 Alcatel 1B 2020 Screen Replacement: 步骤 4 中的图像 2,3 Alcatel 1B 2020 Screen Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to pry the midframe from the bottom case.
    • Slide the end of the opening tool around the perimeter of the device to release the clips holding the midframe and bottom case together.
    • Be careful, the motherboard is located right beneath the midframe.
    • Remove the midframe from the phone.
    询问修复机器人
    添加评论
  5. Alcatel 1B 2020 Screen Replacement: 步骤 5 中的图像 1,3 Alcatel 1B 2020 Screen Replacement: 步骤 5 中的图像 2,3 Alcatel 1B 2020 Screen Replacement: 步骤 5 中的图像 3,3
    • Place a spudger or an opening tool under the camera press connector edge and pry straight up to disconnect it.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • Use the tweezers to pull the rear camera out.
    询问修复机器人
    添加评论
  6. Alcatel 1B 2020 Screen Replacement, Motherboard: 步骤 6 中的图像 1,2 Alcatel 1B 2020 Screen Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Insert a spudger or opening tool under the edge of the front camera cable connector and pry straight up to disconnect it.
    • Disconnect the other two press connectors near the red part of the motherboard.
    询问修复机器人
    添加评论
  7. Alcatel 1B 2020 Screen Replacement: 步骤 7 中的图像 1,3 Alcatel 1B 2020 Screen Replacement: 步骤 7 中的图像 2,3 Alcatel 1B 2020 Screen Replacement: 步骤 7 中的图像 3,3
    • Use tweezers to remove the motherboard from the phone.
    询问修复机器人
    添加评论
  8. Alcatel 1B 2020 Screen Replacement, Front Camera: 步骤 8 中的图像 1,3 Alcatel 1B 2020 Screen Replacement, Front Camera: 步骤 8 中的图像 2,3 Alcatel 1B 2020 Screen Replacement, Front Camera: 步骤 8 中的图像 3,3
    • Place the motherboard to the side.
    • The front camera ribbon connector was already removed in the previous step.
    • Use tweezers to pull the front-facing camera from the smartphone.
    询问修复机器人
    添加评论
  9. Alcatel 1B 2020 Screen Replacement, Screen: 步骤 9 中的图像 1,3 Alcatel 1B 2020 Screen Replacement, Screen: 步骤 9 中的图像 2,3 Alcatel 1B 2020 Screen Replacement, Screen: 步骤 9 中的图像 3,3
    • Flip your Alcatel 1B 2020 face up so the screen is facing you.
    • Slide the edge of the Jimmy between the case and the screen to pry it from the phone.
    • Insert opening picks under the screen as you work around the edge with the Jimmy to keep the adhesive from reattaching.
    询问修复机器人
    添加评论
  10. Alcatel 1B 2020 Screen Replacement: 步骤 10 中的图像 1,3 Alcatel 1B 2020 Screen Replacement: 步骤 10 中的图像 2,3 Alcatel 1B 2020 Screen Replacement: 步骤 10 中的图像 3,3
    • The screen will eventually lift with enough prying.
    • Flip the device over.
    • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
    • Carefully slide the ribbon cable out from the opening at the edge of the frame.
    询问修复机器人
    添加评论
  11. Alcatel 1B 2020 Screen Replacement: 步骤 11 中的图像 1,3 Alcatel 1B 2020 Screen Replacement: 步骤 11 中的图像 2,3 Alcatel 1B 2020 Screen Replacement: 步骤 11 中的图像 3,3
    • Flip the device back over.
    • The LCD screen is very fragile. Be careful when prying and handling it.
    • The ribbon connector for the LCD screen was disconnected in the previous step, so the screen will pop up using the Jimmy.
    • Slide the Jimmy between the LCD and the digitizer to separate the two components.
    • Lift the LCD screen out with tweezers or your hands.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 73
