跳转到主内容
加入维修社区 - 创建账户
Alan 48 Excel: Reception problems? No problem!
你所需要的
      • First of all: Power off! Switch it off and unplug the device.
      • Then grab your screwdriver and undo the screws on the housing.
      • Carefully lift off the housing and put it to one side.
      询问修复机器人
      添加评论
      • Check all cables and connections. Are they properly seated?
      • Especially important: Check the connections to the antenna and the loudspeaker.
      询问修复机器人
      添加评论
      • Time for some contact spray and brushes! Spray the connections thoroughly.
      • Wait a few minutes, then wipe away the residue with a clean cloth.
      询问修复机器人
      添加评论
    1. Alan 48 Excel: Reception problems? No problem!, Check the transistor “Q104 (KTK 161)”: 步骤 4 中的图像 1,1
      • Find the transistor “Q104 (KTK 161)” on the circuit board. Here it is:
      • Take your multimeter and check the transistor. If it is defective, it must be replaced.
      询问修复机器人
      添加评论
    2. Alan 48 Excel: Reception problems? No problem!, Replace transistor “Q104 (KTK 161)”: 步骤 5 中的图像 1,1
      • In order to replace the transistor, carefully desolder the connections. This is where you need to start:
      • Insert the new transistor and solder it in place.
      • Check the connections with the multimeter to make sure that everything is properly working.
      询问修复机器人
      添加评论
      • Put the housing back on and tighten the screws.
      • Plug in the plug, switch on the device.
      • Test whether the reception is now better.
      询问修复机器人
      添加评论
结论
That's it! With these steps, your Alan 48 Excel should have top reception again. If not, a major repair may be necessary.
取消:我没有完成这个指南。
3等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Ingo Bünnemeyer
于06/06/16注册
248 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 39
总计 2,002
