跳转到主内容
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
aaron thielk
aaron thielk5 其他贡献者
最后更新于 February 19, 2016
5 - 10 分钟
简单
This guide will show you how to adjust the height of the handle bars and align the stem with the front wheel.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 步骤 1 中的图像 1,2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 步骤 1 中的图像 2,2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 步骤 2 中的图像 1,3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 步骤 2 中的图像 2,3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 步骤 2 中的图像 3,3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 步骤 3 中的图像 1,3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 步骤 3 中的图像 2,3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 步骤 3 中的图像 3,3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
终点
另外一个人完成了本指南。
aaron thielk
于10/10/10注册
1,903 声望
创作了5篇指南
团队
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G13
4 名成员
创作了17篇指南
一条评论
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 21
总计 9,363
