跳转到主内容
Acer Spin 3 SP315-51-757C Hard Drive Replacement
Skyler Ognibene
Skyler Ognibene3 其他贡献者
最后更新于 March 24, 2022
10 - 15 分钟
中等
When an Acer Spin 3 SP315-51-757C turns on, but the operating system does not start, there is usually a problem with the hard drive. You may also want to get a hard drive with more storage and use it to replace your old hard drive. This guide shows you how to properly unplug and remove your hard drive from your laptop. When installing a brand new hard drive, be sure to have Windows installed onto the hard drive before putting it in your laptop.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Acer Spin 3 SP315-51-757C Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer Spin 3 SP315-51-757C Hard Drive Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 2 中的图像 1,3 Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 2 中的图像 2,3 Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Acer Spin 3 SP315-51-757C Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Loosen the single Phillips #0 screw holding the hard drive in place.
  5. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 5 中的图像 1,2 Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Gently lift the closer side of the hard drive out of its slot.
    • Make sure not to pull too hard on the cables plugged into the motherboard.
  6. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Carefully unplug the cable connected to the side of the hard drive.
  7. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 7 中的图像 1,2 Acer Spin 3 SP315-51-757C Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Remove each rubber edge from the hard drive, and reassemble with a new hard drive.
结论
2等其他人完成本指南。
2指南评论
Awesome. Thanks for the tips here. Do you have any recommendations on what SSD may go with Acer Spin 3 SP315-51-757C ? I am a little clue less here since i am new to this, and any feedback here would help. Thanks.
S B - 回复
I just replaced my HDD with a 1TB Crucial MX500 SSD. It was easy to clone the drive and simple to install. My computer went from almost unusable to better than new, I highly recommend it.
Adam Kahler -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 48
总计 4,659
